Copying the whole e-mail body into excel
elbrodero
I am currently trying to figure out how to copy an e-mail text (from my newest unread mail) into excel. Manually it works just fine but I would like a code to do it.
I have the following code:
Const olFolderInbox As Integer = 6
Const AttachmentPath As String = "Y:\Do\"
Sub Avis7()
Dim task
Dim olNamespace As Object
Dim olApp As Object
Dim olNs As Object
Dim olFolder As Object
Dim olRecip As Object
Dim oOlItm As Object
Dim oOlAtch As Object
Dim oldsubject As String
Dim strBody As String
Dim y As Workbook
Set y = ThisWorkbook
Dim Str As String
Dim Str1 As String
Dim Str2 As String
Dim j As Integer
Dim i As Integer
Dim k As Integer
Set olApp = GetObject(, "Outlook.application")
Set olNs = olApp.GetNamespace("MAPI")
Set olRecip = olNs.CreateRecipient("bbb@bb.com")
Set olFolder = olNs.GetSharedDefaultFolder(olRecip, olFolderInbox).Folders("09")
If olFolder.Items.Restrict("[UnRead] = True").Count = 0 Then
MsgBox "no unread mail"
For Each oOlItm In olFolder.Items.Restrict("[UnRead] = True")
If oOlItm.SenderEmailAddress = "hello@google.de" Then
strBody =oOlItm .body
y.Sheets(1).Range("A1") = strBody
Unfortunately, absolutely nothing happens when I execute the code. Not even an error message.
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Thiago Manzano Copying E-mails to a folder on HD Using Outlook 1
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
K Outlook 2010 Not responding after IMAP folder deletion or copying. Using Outlook 2
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
S Calendar items are not being uploaded to outlook.com after copying Using Outlook.com accounts in Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
L Copying Emails using drag and drop Using Outlook 2
O New to Outlook 2013, dealing with copying vs. moving sent items Using Outlook 0
S Recover messages that disappeared when copying to folder Using Outlook 1
S Copying multiple messages to folders and keeping date/time detail Using Outlook 1
D Copying POP3 folders from Inbox to IMAP Inbox in Outlook 2003 Using Outlook 0
M Copying setups for mutiple users Using Outlook 2
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
A Copying additional contact fields when chosing "Contact from the same company" Using Outlook 5
A Copying cc email addresses to Excel - does not copy the <joe.bloggs@isp.com> Using Outlook 1
S Search Indexing (Copying Folders) Using Outlook 0
E Copying multiple folders to PST Outlook VBA and Custom Forms 2
B Copying data between atbs in a custom form Outlook VBA and Custom Forms 4
R copying a custom view from a public folder and distributing programatically Outlook VBA and Custom Forms 3
N error when copying outlook data "can not copy: the path too deep" Using Outlook 6
N Copying outlook macros between pcs Outlook VBA and Custom Forms 1
R Copying Data from Exchange to PST file Outlook VBA and Custom Forms 1
V Copying contents from one field to another field Outlook VBA and Custom Forms 6
V Calendar - Clearing the whole Calendar Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
MrMayor SENT mail not reloading to top?? Using Outlook 4
ThinkToday Calculate reply time of outlook mail Using Outlook 1
B Outlook 2010 Opening Mail Attachment Using Outlook 2
D Mail in Sent Items Gone Using Outlook 12
