Correct Format of custom Yes/No Checkboxes
witzker
Through years I have custom designed contact form in use and add additional custom designed fields time by time.
Now I have some problems.
I have some check boxes beside each other which are sometimes displayed more narrow than normal (than the others).
I went to look at their properties but layout is the same as all other check boxes.
But what I found is that some check boxes have
Type: Yes/No
Format: Symbol some have Format: Yes/No
Property: Value
First I think all check boxes should have correct settings, therefore my first question is:
What settings should I choose.
The check box should display only YES or NO (checked or unchecked)
If I add a new field the default should be NO (unchecked)
I have 6.000 important records in my contact folder.
Can I do the changes without loosing data?
2nd question:
What I found also is that only some of the custom defined fields are also seen in "all fields" "in the folder".
How can I get my custom designed fields from the "element" (form) also to the "folder" where the contacts are?
(it is not the standard contact folder)
Many thanks for your answers that I can start today in viewing all my approx. 50 check boxes to correct them to the right value.
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
L Email with correct To address but displaying name of a related person Using Outlook 0
Thorsten show the correct calendar on start Outlook VBA and Custom Forms 5
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
R VBScript Sendmail not selecting correct 'from' address Outlook VBA and Custom Forms 3
I Large emails not sent from correct account Using Outlook 0
J Importing to the correct calendar from Excel 2010 to Outlook 2010 Outlook VBA and Custom Forms 2
A phone numbers fields in BCM are not correct BCM (Business Contact Manager) 3
E Getting Outlook full name correct with AddressLayout Using Outlook 1
D Journal problem recording correct phone number Using Outlook 7
B Outlook 2010 asking for password constantly, won't accept correct one Using Outlook 5
M help correct code Using Outlook 0
J Correct settings for send/receive groups w/Exchange Using Outlook 3
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
D How to correct Outlook Connector Live ID Using Outlook.com accounts in Outlook 1
D appointments on To Do Bar don't reflect the correct Calendar Using Outlook 3
M Auto-correct Contact fields' formatting? Using Outlook 7
S Send receive with ATT returns this error: 0x800CCC92 . My password is correct. Using Outlook 2
K Why is OL not keeping the correct sender account? Outlook VBA and Custom Forms 1
E Some question if I understand user properties correct Outlook VBA and Custom Forms 3
S Correct way to Identify is Mail is opened in Edit Mode Outlook VBA and Custom Forms 1
Q Need advice for correct event Outlook VBA and Custom Forms 1
L Time format in Outlook calendar and emails Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
M font format discrepancies with Quick Parts Using Outlook 1
S Email Format With Embedded Images and Tables Change Using Outlook 2
G How to filter by the format of an email address Using Outlook 6
R Lost PST files after format Using Outlook 6
fitzgerald Lost PST files after format - how to recover deleted files? Using Outlook 3
Dr. Demento Outlook output to array -> Excel & re-format Using Outlook 2
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
skylark53 Loss of default format on deleting signature Using Outlook 5
O Setting default format for composing/replying to emails Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
O VBA to change message format and add formatted signature Outlook VBA and Custom Forms 1
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
