Help Please!!! Outlook 2016 - VBA Macro for replying with attachment in meeting invite
JaCrispy
Outlook 2016 64 bit
So I have VBA code to reply to a normal email with attachment, but I need help to modify the code below so that it can also work when you reply from a meeting invitation using email to include the attachments that are included in that meeting invite. If you use the "forward" option from a meeting invite, it forwards the actual meeting invitation, which is not what I would like to do. I would like to reply to the meeting invite and include the attachments.
Sub ReplyWithAttachments()
    Dim rpl As Outlook.MailItem
    Dim itm As Object
    Set itm = GetCurrentItem()
    If Not itm Is Nothing Then
        Set rpl = itm.Reply
        CopyAttachments itm, rpl
        rpl.Display
    Set rpl = Nothing
    Set itm = Nothing
    Set objApp = Application
        Case "Explorer"
        Case "Inspector"
    Set objApp = Nothing
End Function
Sub CopyAttachments(objSourceItem, objTargetItem)
   Set fso = CreateObject("Scripting.FileSystemObject")
   Set fldTemp = fso.GetSpecialFolder(2) ' TemporaryFolder
   strPath = fldTemp.Path & "\"
   For Each objAtt In objSourceItem.Attachments
      strFile = strPath & objAtt.FileName
      objAtt.SaveAsFile strFile
      objTargetItem.Attachments.Add strFile, , , objAtt.DisplayName
      fso.DeleteFile strFile
   Set fldTemp = Nothing
   Set fso = Nothing
Because you don't reply to meetings, Set rpl = itm.Reply won't work. I think you'll need to create a new message - there is a send mail to attendees command but i don't know if it is exposed in the object model. (will look later)
Set replyMeeting = Application.CreateItem(olMailItem)
  replyMeeting.Body = item.body
  replyMeeting.Subject = "Re: " & item.subject
  replyMeeting.To = item.organizer ' not sure if this is right
  replyMeeting.Display ' use .send to send
if you want to reply to all attendees, see Send an email to attendees who have not responded (it can be tweaked to reply to all)
JaCrispy
Outlook 2016 64 bit
Thanks for your tip. I have tried implementing it, but it's not working so far :\
JaCrispy
Outlook 2016 64 bit
Actually.. I did get it working, but the format of the body of the invitation gets stripped out and any pictures etc are missing. any ideas?
Baby steps...
This works (you need the functions from your macro) - but you need to select all and copy the appt body to the clipboard before running the macro. :(
Sub ConvertSelectionToAppointment()
' You need the GetCurrentItem Function from
'http://slipstick.me/e8mio
    Dim objMail   As Outlook.AppointmentItem
    Dim objAppt As Outlook.MailItem
    ' Add reference to Word library
    ' in VBA Editor, Tools, References
    Dim objInsp As Inspector
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
    Set objMail = GetCurrentItem()
  If Not objMail Is Nothing Then
            Set objInsp = objMail.GetInspector
        With objSel
           'use wholestory to copy the entire message body
 ''            .WholeStory
  '           .Copy
    Set objInsp = replyMeeting.GetInspector
    Set objSel = objDoc.Windows(1).Selection
CopyAttachments objMail, replyMeeting
    objSel.PasteAndFormat (wdFormatOriginalFormatting)
    objSel.Range.InsertParagraphBefore
  replyMeeting.Subject = "Re: " & objMail.Subject
  replyMeeting.To = objMail.Organizer ' not sure if this is right
    objMail.Categories = "Appt" & objMail.Categories
    Set objAppt = Nothing
    Set objMail = Nothing
C Please Help outlook 2013 Using Outlook 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
D Help please my Outlook is frozen Using Outlook 3
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
B Please help! Outlook, Exchange Server, and Customization BCM (Business Contact Manager) 2
B Please help! Outlook, Exchange Server, and Customization Exchange Server Administration 0
C outlook hotmail connector update killed my outlook - please help!! Using Outlook.com accounts in Outlook 3
R i want notifier in outlook express , please help how can i get ? Outlook VBA and Custom Forms 1
C Outlook 2007 Wacky Issue - Please Help Outlook Wishlist 1
V Outlook macro help please Outlook VBA and Custom Forms 23
A Help with VBA please! Outlook VBA and Custom Forms 15
J Please help to clarify an IMAP issue Using Outlook 7
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
A help please -Boolean - can I use .AND NOT etc in a rule Exchange Server Administration 0
C Can't import distribution list - help, please Using Outlook 1
V [duplicates duplicates duplicates] please help Using Outlook 26
I can't view email body please help! Using Outlook 6
S Please help! -- Linked Account field at Business Contacts tab is always empty BCM (Business Contact Manager) 1
M Updates to exchange server broke code - please help Using Outlook 2
K shared inbox help please Using Outlook 0
P Please Help me Create a Macro ! Using Outlook 2
J Help please Using Outlook 30
D A little bit of help with headers please? Exchange Server Administration 1
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 5
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 1
D Please help. My live.edu mail will not sync. Using Outlook.com accounts in Outlook 1
M Help with shared BCM file please BCM (Business Contact Manager) 5
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
L Please help an idiot with BCM & Networking... BCM (Business Contact Manager) 5
V Import multiple vCard files!!!!!!! PLEASE HELP Using Outlook 2
