Outlook for Mac Keeps Dropping Offline
hbmiller
Outlook 2016 for Mac
Running Outlook for Mac 2016 (current version 16.13, but same problem in prior versions) on three Mac laptops with a Rackspace Exchange Server account. All three experience the same issue. After running well, often for several hours, the account goes offline and produces a popup error message:
"The server for account [ ] returned the error "Logon failure: unknown user name or bad password." Your username/password or security settings may be incorrect. Would you like to try re-entering your password?"​
If I click on "no," and then "send/receive," the system reverts to normal, usually for another few hours, without having a password re-entered.
I have tried all of the obvious fixes, including deleting all Microsoft identity chains. Has anyone seen this or experienced it? Is there a fix?
hbmiller
It is solely accessed using Exchange -- including on three iOs devices (which do not experience this problem) and on one Windows 7 device (which does not experience this problem). It seems to be limited to the Mac Outlook clients.
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
peterbata Shared Tasks Outlook for Mac Using Outlook 3
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Calendar Printing Assistant 2
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
Marc2019 Cannot setup Outlook Account on Mac Os 10.6.8 Using Outlook 3
P Outlook 2011 for Mac SEARCH Using Outlook 0
P "Edit Message" feature removed in Outlook 2016 for Mac Outlook VBA and Custom Forms 0
Diane Poremsky Outlook for Mac Version Numbers New Slipstick.com Articles 0
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
T outlook cal for mac changes times of recurring meetings on its own Using Outlook 1
Mr Mayor Outlook: MAC and WIN, can't we all get along? Using Outlook 6
G Moving "Delete" button on Outlook for Mac Using Outlook 1
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
C Outlook on Mac & PC Folders not showing up Using Outlook 1
S Syncing categories in Outlook for Mac 2011 with Exchange or Gmail Using Outlook 0
S MAC outlook doesn't show the meeting organizer detail Using Outlook 0
C Error Code -3253 Outlook for MAC Using Outlook 0
H Outlook Disappeared from MAC applications Using Outlook 0
B Outlook 11 for Mac - Imap or Pop Account Type Using Outlook 6
M authentication settings for outlook for mac 2011 Using Outlook 1
Y Moving outlook data/profile from windows 2010 to mac 2011 Using Outlook 3
J Sending Mail From A Different Address Using Outlook 2011 for Mac Using Outlook 0
C [outlook-users] Outlook for Mac Using Outlook 14
C import pst in Outlook 2011 for Mac Using Outlook 0
A Outlook 11 for Mac won't print e-mail attachments Using Outlook 6
S Outlook 2011 for Mac - Exchange Server address changes from public front-end to internal hub server Using Outlook 5
R SDK for Outlook on Mac Outlook VBA and Custom Forms 1
V Outlook behaving oddly Using Outlook 2
M HTML email signature in Outlook Using Outlook 1
M Respond to Outlook Email Outlook VBA and Custom Forms 0
U Outlook locking up when replying to Email Using Outlook 4
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
P Syncing Outlook & iPhone Calendars Using Outlook 4
S Unable to extract text from an Outlook email message Using Outlook 2
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
F Outlook 365 is "Possessed" Using Outlook 2
