Body text of email disappears when I scan an attachment from printer to email
Deb
Outlook 2016 64 bit
Hi there - others have had similar problem, but the answers seemed not to fix. Has Microsoft sorted this out properly yet? I scan a document that I wish to send by email. So I scan to email. Then I add my text that goes with the email and press send. Then when I look in the sent items, the message shows the scan having been sent, but all my correspondence typed into the email has disappeared. What the...
S Body text of Email from invite date/time Outlook VBA and Custom Forms 8
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
E Button in body of email to approve/reject with original text Using Outlook 1
Q Unwanted symbols appearing in email body text Using Outlook 1
K Large body text in email Using Outlook 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
L auto copy text in mail body to other part of the body Outlook VBA and Custom Forms 1
M Extract text in existing message body for use in newmail items Using Outlook 17
R How to format text within appointment/meeting body? Using Outlook 6
I Outlook Appointments - Setting default text in message body Using Outlook 3
J Form 'While You Were Out' body text not working Using Outlook 24
P HTA creating Outlook MeetingItem - need formatted body text Using Outlook 4
O pasting text in body of calendar events Using Outlook 5
L No body text in Outlook 2010 messages Using Outlook 0
B Received Plain Text Message - Body Grayed Out Using Outlook 1
F I cannot highlight text in Microsoft Outlook 2010 e-mails, and copy/paste to the body of another e-m Using Outlook 3
R Outlook 2010: Text in Body Being Change, HTML tags/code showing Using Outlook 3
C Outlook 2007 No text in Message body Using Outlook 1
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 37
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 2
A Outlook 2007 Calendar: Text in the body of a Meeting disappears Using Outlook 1
S outlook spelling check subject different from body text (english / portuguese) Using Outlook 1
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 5
L Printing Outlook - Text Body wraps at 1.5 inches Using Outlook 1
H Exchange 2010 CSV attachment show as body text instead of Attachment Exchange Server Administration 2
S write and format a piece of text in the body using vba Outlook VBA and Custom Forms 7
M How to input text at the beginning of the body of a message. Outlook VBA and Custom Forms 1
M Append text to (formatted) body of Reply Outlook VBA and Custom Forms 2
P How to get Selected Body message Text Outlook VBA and Custom Forms 7
T How can i save the body as text file Outlook VBA and Custom Forms 1
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
