Entered data in custom field goes in card and does not stay in list view
Greer2018
Outlook 2016 64 bit
We have been using a custom field for some time now. While in list view, it would display the information enter (A date). We recently created a new contact card template that had some additional fields and launched that. In the new template we used the same custom field as well as some new fields. However, now in list view it is sporadic about the data it shows in this field. Sometimes it has the date and sometimes it says "none". If we type from list view a date, it will keep the date in the contact card but still does not always display it in list view.
Can someone help?
witzker
I think you need to have the custom field in both
The form
The folder
Or if the data are shown correct when you open the form - edit the list viev by using the custom field from form
Hope this helps
G Can't find contacts entered Using Outlook 0
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
C Can't create Outlook data file Outlook Wishlist 0
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky How to Compact the Data File When you Close Outlook New Slipstick.com Articles 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
Diane Poremsky Rename Email Accounts and Data Files in the Folder List New Slipstick.com Articles 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
M Dilemma: to add to existing data file or not to? Using Outlook 16
R Exporting Excel data to Outlook 2016 Calendar Outlook VBA and Custom Forms 20
Diane Poremsky Data loss may occur during public folder migration New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
A How to export one email data to excel Using Outlook 1
Diane Poremsky Create Appointments Using Spreadsheet Data New Slipstick.com Articles 0
S Outlook data file cannot be accessed message Using Outlook 5
L outlook data file confusion Using Outlook 1
M Extracting cell data from table Outlook VBA and Custom Forms 2
M Data File Management confusion after migration Using Outlook.com accounts in Outlook 1
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
