Calling a Public sub-routine from the script editor via VB script
Jacob Vaid
I have a public subroutine called "Forward". This is located within the "Thisoutlooksession" class module .
I am trying to call this code using a command button via the script editor.
I have not done this before. Therefore, any help in this regard would be a great help to me.
Jacob Vaid
Thanks a lot Diane for replying back. For some reason, the code below is not working.
Private CommandButton3_Click()
complete
End sub
Do we use private subs in the Outlook VB script editor? I am fairly new to the outlook script editor. So, if this question sounds silly, please excuse me.
If I may digress a little bit, can you please guide me with the code to "forward" an email. I want to place it behind a command button within one of my custom forms.
Looking forward to your guidance.
witzker
I look for same solution
Have you solved it?
Michael Bauer
You can try this syntax
ThisOutlookSession.Forward
If that doesn´t work either, it´s probably blocked for security reasons. An alternative would be to move the method to a module (not a class module).
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
A Calling one module from another Outlook VBA and Custom Forms 2
I Calling from Outlook Using Outlook 2
G Latest Exchange Rollup - Management Console Error - Exception calling "GetSteppablePipeline" Exchange Server Administration 1
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
H Auto-Dialer for calling contact Using Outlook 2
T PR_MESSAGE_CLASS is reset when calling Save() on item Outlook VBA and Custom Forms 4
A Created a personal group that now appears to be a public group Using Outlook 3
F How to assign a task to a public task folder? Using Outlook 1
C Outlook 2016: Searching in all (+public) folders Outlook VBA and Custom Forms 9
L Public folders permissions Exchange Server Administration 1
Diane Poremsky Mail-enable Exchange Public Folders New Slipstick.com Articles 0
Diane Poremsky How to Send Email When Traveling or Using Public Wi-Fi New Slipstick.com Articles 0
Diane Poremsky Data loss may occur during public folder migration New Slipstick.com Articles 0
S Empty an Office365 public folder containing 20.000 messages Using Outlook 2
D Priasoft Public Folder Syncro? Exchange Server Administration 0
I Random Chinese characters in email copied from a pst file. Exchange Server 2016 Public Folder Exchange Server Administration 1
P Public Folder email error, ndr returned. Exchange Server Administration 1
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
L any ways to create shortcuts to a public mail folder Using Outlook 4
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
N Public Folder Calendar Permissions Exchange Server Administration 4
V Macro to open Public Folders subfolder? Outlook VBA and Custom Forms 1
S Contacts disappear in public folder search Using Outlook 1
R How to Block from sending mail to public domain. Using Outlook 8
I how to create appointment using saved template onto public folder shared calendar Using Outlook 3
M Codetwo Public Folders structure for vba Outlook VBA and Custom Forms 13
M How to copy attachments from a Public Folder in VBA Outlook VBA and Custom Forms 3
G Outlook 2013 - Default View for Public Folder Contacts Using Outlook 1
V Extracting user-defined details from a public folder Outlook VBA and Custom Forms 2
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
D How do I mail-enable a Public Folder Sub-folder in exchnage 2007 using shell ? Exchange Server Administration 0
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
E Outlook 2007 Saves .MSG E-Mails with attachment from Public Folders as RTF Using Outlook 0
S Pushing GAL to a public folder Exchange Server Administration 2
T Public Folder has many messages but can't be seen in Outlook Using Outlook 3
C How do I share/post my calendar to public folders Exchange Server Administration 3
T managing contacts in public folders Using Outlook 4
