Remove text in subject using VBA
danlyng
Outlook 2013 64 bit
In my company there has been made a new feature whenever we get an email from an external sender.
Text i subject can now be: "[CAUTION: EXTERNAL EMAIL] Agenda for meeting wednesday" as before it would just have stated "Agenda for meeting wednesday"
The annoying thing about it is that the text [CAUTION: EXTERNAL EMAIL] does not remove itself when I send a reply.
I would like af code to put into ThisOutlookSession.
I have tried this one but without luck:
Sub mymacro ()
dim arr as variant,i as long
arr=array("[CAUTION: EXTERNAL EMAIL]")
for i=0 to ubound(arr)
oitem.subject=replace(oitem.subject,arr(i),"",,,vbtextcompare)
next
oitem.subject=trim(oitem.subject)
oitem.save
is that the only test you need to replace? if so, don't use the arrary.
oitem.subject=replace(oitem.subject,"[CAUTION: EXTERNAL EMAIL]","")
if you want ot use an array, see Using Arrays in Outlook macros
try For i = LBound(arr) To UBound(arr)
Ah. It makes sense in the way you were using it. :)
F VB Script, remove text from subject line when forwarding Using Outlook 22
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 14
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Remove Office 2013 Update Banner New Slipstick.com Articles 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File New Slipstick.com Articles 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Diane Poremsky How to remove the primary account from Outlook 2010/2013 New Slipstick.com Articles 0
Diane Poremsky Remove an Address from Reply All New Slipstick.com Articles 0
Diane Poremsky Remove Outlook apps from Outlook New Slipstick.com Articles 0
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T How to remove annoying Big Blue Type at beginning of my messages Using Outlook 2
H Cannot remove unwanted fields from form Outlook VBA and Custom Forms 9
T How to remove "automatically delete messages form this sender"? Using Outlook 1
M How to remove duplicate history items BCM (Business Contact Manager) 7
D Isn't there an easy way to remove duplicate contacts in outlook? Using Outlook 1
Britonius Exchange Powershell to Remove Reviewer access from all Folders in a mailbox? Using Outlook 3
