help with outlook scripting
sblee
Outlook 2013 64 bit
Dear All
Really appreciate if someone can help on this. As i am very bad with Vba scripts.
Is there anyway to auto fill in the "X" in the Approve checkbox when i receive an email such as below and auto reply to the sender?
Example:
Sender: XXX@email.com.sg
==Email body start==
Mark "X" if you approve in the checkbox below
Approve ( ) Reject ( )
==Email body end==
sblee
Outlook 2013 64 bit
Thanks Diane, appreciate it!
If it's not too much to ask, If i wanted to reply to the sender after replacing the body. Will the below work?
Sub SendNew (Item As Outlook.MailItem)
Dim objMsg As MailItem
objMsg.Body = replace (item.body, "Accepted ( )", "Accepted (x)")
objMsg.Subject = "FW: " & Item.Subject
objMsg.Recipients.Add "XXX@email.com.sg "
objMsg.Send
in a rule, yes, it should work. Change Send to Display and test it - that will open it on screen so you can see.
to test the script on a selected message, use this macro:
Sub RunScript()
Dim objItem As MailItem
Set objApp = Application
SendNew objItem
sblee
Outlook 2013 64 bit
Thanks for the advice Diane.
I tried the script on my email and it works!
Appreciate the help.
Sent from my SM-G960F using Tapatalk
A newb outlook macro help Outlook VBA and Custom Forms 1
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
E Outlook Contacts Help Using Outlook 1
M Outlook Backup help needed ASAP Using Outlook 2
C Please Help outlook 2013 Using Outlook 1
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
E Outlook Tasks Help Using Outlook 6
F Outlook 2010 - Need help with a custom field. Using Outlook 3
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
C Outlook Profile Corrupt...Help!!!!! Using Outlook 0
M HELP! MSN to Outlook Using Outlook 1
A Outlook HELP Using Outlook 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
S Desperate for Help with Outlook custom form Using Outlook 0
L Outlook 2013 IMAP account is deleting e-mails from my inbox - help!!! Using Outlook 3
J Outlook 2010 Forms Help Needed "A field in this form requires a value." Using Outlook 6
W I Need help with vb.net and outlook 2010 Using Outlook 2
S Help needed - syncing outlook emails with iphone 4s Using Outlook 4
S Outlook macro help Using Outlook 10
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
A URGENT Help in Outlook Meeting Using Outlook 3
D Help please my Outlook is frozen Using Outlook 3
makinmyway Help Using Windows Desktop Search to Index Outlook PST of another User Logon Using Outlook 14
E Outlook PST files disappear, only found temp file HELP: Using Outlook 1
A outlook printing assistant Help editing template Calendar Printing Assistant 3
M Anyone with this Microsoft Outlook issue can help? Using Outlook 1
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
P help me plase !!! outlook 2007 I can see mail Bcc Using Outlook 1
