Advanced Search in MS Outlook by VBA and SQL
Bamerand
Outlook 2013 32 bit
Here is a code I was able to modify to meet my expection (got from www.slipstick.com). It loops thru entire Outlook and find (in different PST) emails received / sent within today. So far so good. Now, it also searches for and finds Outlook items such new contacts in "Recipient Cache", "Tasks", "Calendar" and "Sync Issues". Is there a way to add a line that will allow to skip the above mentioned "Recipient Cache", "Tasks", "Calendar" and "Sync Issues"? Filtering does not do good as the filter enableed search process slowes down the PC by almost 10 times, for with no filter applied the search takes no more that 15 seconds in total, meanwhile enabling filter in views makes the search more than 2.5-3 minutes. I am open to any suggestions.
Sub SentToday()
Dim myolApp As New Outlook.Application
Dim tDate As Date
On Error GoTo ErrHandler
tDate = Date 'Today
txtSearch = "sent: (=" & tDate & ")"
myolApp.ActiveExplorer.Search txtSearch, olSearchScopeAllOutlookItems
Set myolApp = Nothing
ErrHandler:
MsgBox "Oops, an error has occured." & vbCrLf & vbCrLf & "Error Code : " & Err.Number & " , " & Err.Description
Call GoToMyInbox
Bamerand
Outlook 2013 32 bit
Dear Diana,
Thank you! That was helpful! :)
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
O Advanced search - can I use booleans Using Outlook 3
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
M Something went wrong and your search couldn't be completed Using Outlook 1
L New Location for the Search Bar Using Outlook 6
