Calender and contacts in trash
TerryOConnor
My Calendar and Contacts folders are in Trash, probably because of this:
"If you use iCloud and an IMAP account is set as default, it moves the Calendar, Contacts, and Tasks folders to the IMAP account’s Trash folder, to lessen the chances you’ll create items in those folders."
I did use iCloud but no longer do so. How do I move these folders back where they belong? It looks as if the folder system is causing problems with my sync software.
I also get frequent messages popping up saying my Outlook account is out of date.
If I uninstall and reinstall Outlook, will that work?
restart outlook using the /resetfolders switch. You may need to move the appointments (use a list view) and contacts to the default folders.
Close Outlook. Right-click on the Start button and choose Run or press Windows key + R to open the Run command. Type or paste the following into the Open field and press Enter or click OK to restart Outlook. (There is a space before /.)
outlook.exe /resetfolders
This will reset the folder assignments to the default folders for the account and recreate any missing folders.
M Is Outlook Connecter Mandatory to Sync Contacts/Calender? Using Outlook 3
A Synchronization Error of contacts and calender using Outlook connector Using Outlook.com accounts in Outlook 12
A How to use calender printing? Calendar Printing Assistant 1
L Calender reminder emails Using Outlook 3
B Importing Text from Excel to Outlook 2013 Calender Using Outlook 0
B Import Excel Text into Outlook Calender Using Outlook 4
vipin Calender Exchange Server Administration 1
O Pop-up alert calender Outlook Wishlist 3
Edaniels Adding Week Number on Calender Using Outlook 2
D Add tasks to reminders and calender? Using Outlook 1
J Calender notifications from a shared generic mailbox. Using Outlook 1
O Calender first day Sunday won't stay Using Outlook 3
J how to choose which item alone go to pst ? OR how to auto sync/copy calender Using Outlook 1
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
D Calender issue Using Outlook 2
M Custom Contact form queries (date control & contact/calender linking) Using Outlook 1
P Calender in Outlook 2007 wont open Using Outlook 4
A Outlook - Shared Calender Using Outlook 1
S Calender reminders question Using Outlook 13
S Couple of questions related to calender Using Outlook 1
R Outlook 2010 Daily Calender need high detail Using Outlook 2
S How to automate showing the Public Folder Calender to Mail Favorite folder Using Outlook 0
A Calender Permissionis "Other" section settings Using Outlook 1
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
J Limiting time range dislayed on calender - Outlook 2010 Using Outlook 1
A Is there a calender preference for Julian Dates in outlook? Using Outlook 4
V Is there no way to obtain sender's emailid from outlook calender d Outlook VBA and Custom Forms 7
L List of Calender Fields for VBA (Outlook 2007) Outlook VBA and Custom Forms 1
V turn off shared calender reminders/leaving personal calender remin Using Outlook 7
V MSN Calender Using Outlook.com accounts in Outlook 1
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
GregS Exporting contacts Using Outlook 1
