Automatically Forward Emails and Remove/Replace All or Part of Body
Outlook 2016 64 bit
Hi! I'm trying to use a combination of a rule and macro to automatically forward emails I receive with a specific subject and delete or remove two hyperlinks in the body. I primarily want to forward an attachment and don't really mind what happens to the body. If removing the whole body is easier, that's ok.
The rule portion is working fine, but I can't seem to manipulate the body of the automatically forwarded email using any of the VBA I've found on this forum or others. I'm not even sure if the macro is running to be honest! Maybe there's an easier way to accomplish this, such as having one macro forward an email and alter the body rather than trying to use a rule?
Below is the email. The subject will always be "Monthly Local SEO Report," and I'm trying to remove the two hyperlinks at the bottom of the body.
I'm completely new to VBA and macros, only having run a few I found online in Excel, so any help would be greatly appreciated, thank you!
From: Local SEO Notification <bcarson@thinkstrategic.com>
Sent: Friday, June 8, 2018 2:14 PM
To: bcarson@thinkstrategic.com
Subject: Monthly Local SEO Report
An analytics report has been shared with you by Local SEO
has shared a Local SEO Analytics report. It's attached to this email.
Sincerely,
Local SEO Local Search Management
Local SEO
update notification preferences
Outlook 2016 64 bit
Here's the script I'm using
Sub myRuleMacro(item As Outlook.MailItem)
Sub RemoveExpression()
Dim outNS As Outlook.NameSpace
Dim outFldr As Outlook.Folder
Dim outMailItems As Outlook.Items
Dim outMailItem As Outlook.MailItem
    Set outNS = Application.GetNamespace("MAPI")
    Set outFldr = outNS.GetDefaultFolder(olFolderDrafts)
    Set outMailItems = outFldr.Items
    For Each outMailItem In outMailItems
        outMailItem.Body = Replace(outMailItem.Body, "Local SEO", "")
    Set outMailItems = Nothing
    Set outFldr = Nothing
    Set outNS = Nothing
Here's a screenshot of my rule
This is the problem - this is used to process every message in the folder and you don't do this with rules.
Plus the rule wasn't doing anything:
I didn't test this so i might have made a typo, but this is basically what you need - the item is identified by the message the rule is processing and is referenced using Item : (item As Outlook.MailItem)
        item.Body = Replace(Item.Body, "Local SEO", "")
item.save
Outlook 2016 64 bit
Thank you very, very much for the reply! Yes, I had noticed I hadn't set up the script properly yesterday and redid it, still to no avail. I tried your code just now, and still am not having any luck. It's weird the way the rule is ordered. It looks like running the script comes after forwarding the email, but I need the text replaced prior to forwarding it and don't see a way to change the order. Maybe the events are simultaneous? Regardless, below is the script and rule I'm using now. I've simplified the rule since I screen-shot it last to avoid over-complicating it at this stage. I'm still getting "Local SEO" in the body of the mail when I receive it and when it gets autoforwarded by the rule. I noticed in a few similar threads that HTML could be an issue. Do I need to use a different function?
        item.body = Replace(item.body, "Local SEO", "")
item.Save
Again, thank you very much for your time!
You can't use other actions in the rules along with run a script.
This will remove the links from the forward copy and forward it.
Set myForward = Item.Forward
myForward.Recipients.Add "alias@domain.com"
        myForward.body = Replace(myForward.body, "Local SEO", "")
myForward.Send
Outlook 2016 64 bit
Thank you very much for the reply. I've updated the script and removed all other events from the rule; however, it looks like Outlook is having trouble running the script now.
Here's a screen shot of it:
And of the rule:
Any feedback would be greatly appreciated. Again, thank you so much!
Did you try re-selecting the script? It looks like you either moved the script to a module or renamed the module
Outlook 2016 64 bit
Yes, I'm not quite sure what the issue was, but it wasn't quite that. After messing around endlessly, I have gotten it to work; however, it appears that the incoming message is getting forwarded twice. I don't believe this is an issue with the rule or script, as it works when I trigger it by mailing myself, but when I receive an email from a reporting system that triggers the rule it gets double forwarded. Would you happen to know a potential cause of that or how to prevent the same message from getting forwarded twice?
Outlook 2016 64 bit
Please disregard the previous post as I've resolved the issue. I wouldn't have been able to do it without you. Thank you very much!
L Automatically forward ALL outgoing/sent emails to another email adddress (not just for a specific distribution list) Using Outlook 2
P Automatically Categorize Meetings once they are accepted Outlook VBA and Custom Forms 5
D Outlook 2016 automatically increment anniversaries Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
R Make Enter Network Password Prompt Go Away Automatically Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
Diane Poremsky Automatically create a task when sending a message New Slipstick.com Articles 0
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
M Automatically create event in calendar when task is created Outlook VBA and Custom Forms 1
Diane Poremsky Create Appointment From Email Automatically New Slipstick.com Articles 0
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
T Automatically open link in email received Outlook VBA and Custom Forms 33
N Automatically file email messages Using Outlook 2
J Automatically Move Old Items from a Shared Mailbox to a .PST on a Network Drive Outlook VBA and Custom Forms 1
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
D Automatically file message and reply to folder. Using Outlook 1
A Code to automatically delete message after sending Outlook VBA and Custom Forms 6
Diane Poremsky Automatically Create Contacts From Messages New Slipstick.com Articles 1
T Outlook 2010 emails do not refresh automatically Exchange Server Administration 1
L Save Mail Message to new folder created automatically Outlook VBA and Custom Forms 1
G Hae Rules NOT perform automatically? Using Outlook 1
F Automatically close email after selecting mark unread Using Outlook 1
nathandavies How to save emails to a specific folder on a network automatically using a macro Outlook VBA and Custom Forms 14
T Default inbox not automatically sending/receiving Using Outlook 1
Angger Microsoft Outlook 2010 Automatically Restarting Using Outlook 2
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
I Automatically updates outlook 2011 address book Using Outlook 1
