Reply and replyall macro is not working
Bruce Johnson
I am trying to setup a macro so that every time I press reply or reply all, it will set the Send Replies to and then an address, but it is not firing at all.
I have it in the ThisOutlookSession and other codes I have here are working. I have the security settings to allow ALL MACROS
I have made the code VERY simple at this point:
' Reply
'//slipstick.me/44b0w
Private Sub oItem_Reply(ByVal Response As Object, Cancel As Boolean)
Dim z As Integer
z = MsgBox("here")
Private Sub oItem_Replyall(ByVal Response As Object, Cancel As Boolean)
Dim z As Integer
z = MsgBox("here RA")
Hitting the REPLY or REPLYALL do not fire the macro.
I do have another macro in the ThisOutlookSession that works.
I am using MS outlook 2010, (version 14.7208.5000 (32 bit)
Help!
do you also have the app startup code?
Option Explicit
Private WithEvents oExpl As Explorer
Private WithEvents oItem As MailItem
Private bDiscardEvents As Boolean
   Set oExpl = Application.ActiveExplorer
   bDiscardEvents = False
Private Sub oExpl_SelectionChange()
   Set oItem = oExpl.Selection.Item(1)
Diane Poremsky Reply or ReplyAll with Attachments New Slipstick.com Articles 0
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
Vijay Reply all by attachment name Using Outlook 10
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
C Outlook Attachment List in Reply Header Using Outlook 3
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Reply to All Includes My Address New Slipstick.com Articles 0
F Room Mailbox Reply Exchange Server Administration 0
N How to add Dear & mail receipts name while reply to that mail in outlook2007 Outlook VBA and Custom Forms 1
J Force account selection for sending reply emails Using Outlook 1
J Adding Reply & Delete to main toolbar? Using Outlook 0
Diane Poremsky Outlook Crashes When You Reply or Create a New Message New Slipstick.com Articles 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
D Automatically file message and reply to folder. Using Outlook 1
O Reply and Add CC Outlook VBA and Custom Forms 4
