Reading Pane (Reading Pain?) Default Setting
Hello All,
Does anyone know how, on the Outlook 2016 client, permanently to set the Reading Pane for all new folders created to "off" as the default (rather than "Right"). At present, every time I create a new mail folder/subfolder on the left navigation pane, I then have to click on the folder in question and then View->Reading Pane->Off. Boring...:mad:!
View menu > View Settings > Other Settings. Select off. This may or may not apply to all folders using the view - so... Then go to Change View and make a copy of the View. Then apply view to other folders and apply to all folders.
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
M Viewing Custom Form Fields in the Reading Pane and in Replies Using Outlook 3
R Reading Pane text appearing all the way to the right... Using Outlook 1
D Cursor in reading pane Using Outlook 5
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
S Outlook 2010 reading pane not clearing Using Outlook 3
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
V Reading/Posting in Newsgroups Using Outlook 1
A Received Date None after reading Using Outlook 2
P exchange management consoles has stoped working and yes I have read the above article and tried the troubleshooter and spent days reading and trying d Exchange Server Administration 0
M Reading .msg Messages In MS Outlook For Mac 2011 Using Outlook 1
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
J Reading outlook conatcts Outlook VBA and Custom Forms 1
D Getting Started - Reading attachment Outlook VBA and Custom Forms 4
J Reading E-Mails in VBA Outlook VBA and Custom Forms 1
