Retain Original Message When Forwarding With Macro
Randy Schmidt
Outlook 2016 64 bit
I am new to Outlook VBA and cannot figure out how to forward a message with added text, keeping the original message intact. Here is the code I'm trying (and I really don't understand a lot of it):
Sub Forward_Invoice_To_Joseph()
Dim strHTML As String
Dim Msg As Object
Set Msg = HTMLBody
strHTML = "Hi Joseph,<p><p>Please advise if this invoice meets your approval<p><p>Thanks,<br>Randy"
Set objItem = GetCurrentItem()
Set objMail = objItem.Forward
Set objApp = CreateObject("Outlook.Application")
Set objSelection = objApp.ActiveExplorer.Selection
objMail.To = "xxx@xxx.edu"
objMail.CC = "xxx@xxx.edu"
With objMail
.BodyFormat = olFormatHTML
.HTMLBody = strHTML & Msg.HTMLBody
objMail.Display
Set objItem = Nothing
Set objMail = Nothing
Set objApp = Application
Case "Explorer"
Case "Inspector"
Case Else
End Function
I copied and pasted parts of this code from the resources I found (like this website). I am simply trying to preface a forwarded message with what's in strHTML. It took me a long time to figure this part out but it does work. However, the original message is gone when I execute the macro. Please help me understand what I'm doing wrong. Once I do, I have many very similar repetitive messages and forwards that I would replicate using this type of code.
Thank You,
RS
I'm not sure what this does -
Set Msg = HTMLBody
or this
but this works -
With objMail
.To = "xxx@xxx.edu"
.CC = "xxx@xxx.edu"
.HTMLBody = strHTML & .HTMLBody
.Display
Randy Schmidt
Outlook 2016 64 bit
Set Msg = HTMLBody
or this
but this works -
With objMail
.To = "xxx@xxx.edu"
.CC = "xxx@xxx.edu"
.Display
I was experimenting with things that I have no concept of yet! Those commands were pure guesses. I am well-accustomed with writing code in Excel but I haven't yet gotten a feel for Outlook VBA. I'll use it quite a bit more once I gain the needed familiarity. Thanks for your help.
Randy
R How can I retain embedded object with voting button reply? Using Outlook 5
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
D How to retain attachments in message when replying to sender Using Outlook 4
D Script help - retain forwarded email body & location of script Outlook VBA and Custom Forms 5
B disappearing original when attach to email Using Outlook 1
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Diane Poremsky Foward a Message and CC the Original Recipients New Slipstick.com Articles 0
H send reminder if no reply received on first or original email using macro Using Outlook 2
oliv- Why custom form is different from original ipm.contact ? Outlook VBA and Custom Forms 4
S Reply & Forward Date in original message incorrect Using Outlook 2
E Button in body of email to approve/reject with original text Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
R Forwarding and keeping Original intact Using Outlook 3
B Auto reply using macro include original email Using Outlook 4
J Image in original e-mail is hyperlinked when a reply with the image is hyerplinked Exchange Server Administration 1
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
L Auto Forward without presenting the original sender Outlook VBA and Custom Forms 1
J How to redesign the Contact form without losing the original layout? Using Outlook 2
A automatically remove flag from original message when a response was received Using Outlook 2
C Remove iCloud so I can have original outlook calendar and contacts Using Outlook 43
C Hover display of DL shows original owner, not current Using Outlook 2
S Outlook 2k/2k3 Reply or Forward: Signature image replaced by original sender Using Outlook 3
M 2010: sorting by ORIGINAL send date Using Outlook 1
C Create a rule to only check new content in email - disregard original content Using Outlook 3
A Creating a rule that both forwards the original attachment and uses a template Using Outlook 11
R Recall Email Message when i'm not the original sender - Outlook 2010 Using Outlook 2
C Outlook/Exchange 2010 Recover Deleted Items to original folder Using Outlook 2
P Reply to original sender, not to forwarder ? Outlook VBA and Custom Forms 1
S -> [O2007]: get the message HTML original source code? Outlook VBA and Custom Forms 6
R Auto Reply with Original Email and any attachments Outlook VBA and Custom Forms 1
S Original Attachment not removed Outlook VBA and Custom Forms 4
R keep track of the original sender Outlook VBA and Custom Forms 3
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
C Why won't Title display in message list? Using Outlook 1
icacream content in this message could not be downloaded.... Using Outlook 2
R Warn before sending message Outlook VBA and Custom Forms 4
