contact notepad 'style' getting changed after clicking and running Activities
Nan
I had already posted earlier a problem I was having with the contact notepad having bluish squiggly underlines and right clicking suggesting I change the style to Normal.
Now I found out why some have it and not others.
The note pad is fine until I run Activities and then when I go back to the General contact record, there are the squiggly lines.
Far more bizarre than I originally thought.
So now I have done tests and if I copy and paste the entire contents into Word and then take that from Word and put it back into the notepad it stays put. Even if I click on Activities it stays fixed.
So that answers my mystery of why they seem OK and then suddenly change. I thought I was just not good at keeping track of which ones had the issue and which didn't.
And it doesn't seem to matter if the Activities search ends up with results or no results. Happens either way.
And happens whether the contact has an email address in the address field or not. Happens either way.
Nan
OK, found my answer. It started also happening in emails I got from others, like a company. Answer at this link.
How to stop Outlook 2010 from blue-underlining all text in read messages?
R Time for another article on contact cards? Using Outlook 0
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M Contact photos are distorted Using Outlook 0
C Outlook Contact Manager - A viable successor? BCM (Business Contact Manager) 7
N Contact display as Using Outlook 2
N How to turn off autocorrect in contact notepads Using Outlook 2
P AGGGGHHHH!!!! - Address Books and Contact Subfolders Using Outlook 5
G Mass Updating Contact form used Outlook VBA and Custom Forms 8
Rupert Dragwater How to import contact list Using Outlook 15
T One Contact list, two sections of company (none) Using Outlook 2
M regarding legacy contact cards Using Outlook 2
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
E Imported Contact Issues Using Outlook 11
K Contact notes field replicating Using Outlook 6
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
M Contact group shortcut Using Outlook 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
M Mail merge to single contacts + contact groups? Using Outlook 4
C How to avoid sending mail to the wrong contact person New Slipstick.com Articles 1
