The upload of "Calendar" failed. There was a problem with the request.
Mark Foley
We've been using Outlook 2010 at the office for years, and for years users have been able to publish their calendars to an in-house server. Some days ago that stopped working for one user. I've checked the Publish Calendar Settings > Advanced, toggled the 'Update this calendar with the server's recommended frequency' checkbox (left it check), then Clicked OK, OK and got the message, "The upload of 'Calendar' failed. The next upload attempt occurs with the next send/receive. There was a problem with the request." Of course, no mention here of what the problem was.
Following some web advice, I tried Remove from Server, but got the message, "The Calendar was not removed form the server. To remove this calendar, you must delete the file on the server." So, I did that, but still nothing. I still get the "The Calendar was not removed ..." message when I try the Remove from Server option, even though the calendar no longer exists on the server, and I got the follow-up message, "The calendar could not be removed automatically from the server. Updates to this calendar will continue to be published until you remove the calendar from the server. Try to remove it again later." Well, the calendar is removed and updates are not happening. So, I put the calendar .ics file back on the server.
I'm stuck. I'd like to get this calendar re-publishing. What's my solution?
Mark Foley
I figured out the reason this started happening in the first place. While messing with something else I turned off the WebDAV service. This affected all Outlook users. However, when I turned the service back on other Outlook users' calendars resumed updating, but this particular user's calendar did not. I kept getting the same "The upload of 'Calendar' failed" error.
I tried everything I could think of including un-joining and re-joining the domain. Repairing Office, un-installing and re-installing Office. Image restoring the entire workstation to earlier dates. Restoring the PST file to earlier dates. Nothing worked. Finally, I had to remove the user's Outlook profile (after exporting Calendar and Contacts) and re-create it. I imported the saved Contacts and Calendars and re-published the calendar and it all started working again. Unfortunately, this user (who is the organization Director) lost all his color category settings which he lives and dies by. As far as I can tell, there is no way to export and import these settings.
Mark Foley
No, I know IMAP doesn't support Outlook categories (it does support tags used by e.g. Dovecot/Thunderbird). My understanding is that Outlook category/colors for emails are kept in the PST file. I'm only looking for color categories on the email, not the calendar/events. In the past, when installing Outlook from scratch and re-creating the user's account (e.g. new machine), I've had the user open his old PST file and browse those message for color categories settings and manually set his current mailbox message one-by-one. As you can imagine, this is labor intensive and this user is disinterested in doing that again. You once upon a time gave me a VB script to extract the color category settings from Outlook. I've used that to set tags for Thunderbird/IMAP users who migrated from Outlook (doable since we host our own IMAP/Dovecot server). It would be nice if there were a way to import this information to the new Outlook account messages.
Correct, the master category list is stored in the default data file. When you removed the profile, it removed the data file - so you lost the master list. The mail lost the categories because they dont sync back to imap servers - so when the new data file synced, there were not categories.
since you have the message id's, possibly. I'll see if I can find a script that comes close and would be easy to edit.
T Unable to 'Upload a file' using popup 'Browse' button Using Outlook 0
M Emails Wont Upload to from MS Outlook 2010 to Server Using Outlook.com accounts in Outlook 9
J upload my outlook files Using Outlook 1
I Outlook is stuck at "Updating Calendar" Using Outlook 1
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
M Cannot read the calendar Using Outlook 4
Horsepower What is best calendar practice for iMac Using Outlook 3
M Calendar greyed out Using Outlook 0
M Unable to share 2019 calendar Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
Fozzie Bear Sharing Birthday Calendar Using Outlook.com accounts in Outlook 3
M Calendar daily Appointments and printing Calendar Printing Assistant 0
I Google Calendar <calendar-notification@google.com> appearing as a duplicate entry Using Outlook 2
L Sharing Calendar for Only Scheduling Using Outlook 2
B Outlook Calendar not coming down from cloud Using Outlook 2
N Having Shared Calendar shift to Current day Using Outlook 0
O Calendar - appointment templates and categories Using Outlook 1
HarvMan Outlook 365 Calendar Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Calendar Printing Assistant 2
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
J Weekend View in Calendar Using Outlook 1
A Birthdays from .csv to Calendar - arriving day behind Using Outlook 5
C Put Day of Year into Outlook Calendar Outlook VBA and Custom Forms 2
C Outlook Calendar Using Outlook 1
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
TomHuckstep Outlook 2016 Limit the number of days syncing from Google Calendar Using Outlook 1
K Accentuating today in Outlook calendar month view Using Outlook 2
T why are the calendar icons different for different accounts Using Outlook 2
