Scheduled footer change
Treasur2
This is my first post. Feel free to move it where its best.
I want to have a predetermined footer added or changed after a given period of time. Like a week.
Example.
I send email on day one, it contains footer "have a nice day". I get reply. I don't want the same footer being assigned to my reply. I know how to do that.
7 days later I send email in new thread. I want the new footer to be "Have a bad day"?
Treasur2
no, I want the signature field to update its content on a scheduled basis (daily, weekly, monthly,etc.)
V Scheduled backup of imap account Using Outlook 7
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
C Scheduled Task Doesn't work with Outlook 2007 Outlook VBA and Custom Forms 1
S Scheduled backup for BCM Database Tool BCM (Business Contact Manager) 1
C How do you add an attendee to a already scheduled meeting? Using Outlook 3
A Access Outlook's Page Header and Footer Outlook VBA and Custom Forms 3
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 88
P How can I change my calendar view back Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
W Appointment occurrences change the location property Using Outlook 0
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
CWM030 Name Change? Exchange Server Administration 9
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
