Vba to monitor time to respond to emails using a shared mailbox
Billy C
I am using excel vba as I wish to output to excel and match inbox items received into sub folders and the response time by members of a shared mailbox
I have never used outlook vba but have cobbled together the code below from various internet posts so don't fully understand it all so I am looking for your kind assistance and paciance
The code works as expected from my personal inbox giving me the inbox mail items and the relevant response. I added a picker to let me select which inbox sub folder to select mails from and that works also however it does not return responses from the shared mailbox
Can you identify where I am going wrong please
Sorry i couldn't attach the file as it is excel the forum does not allow this file format
Much appreciated
Code used is
Public ns As Outlook.Namespace
Private Const EXCHIVERB_REPLYTOSENDER = 102
Private Const EXCHIVERB_REPLYTOALL = 103
Private Const EXCHIVERB_FORWARD = 104
Private Const PR_LAST_VERB_EXECUTED = "http://schemas.microsoft.com/mapi/proptag/0x10810003"
Private Const PR_LAST_VERB_EXECUTION_TIME = "http://schemas.microsoft.com/mapi/proptag/0x10820040]"
Private Const PR_SMTP_ADDRESS = "http://schemas.microsoft.com/mapi/proptag/0x39FE001E"
Private Const PR_RECEIVED_BY_ENTRYID As String = "http://schemas.microsoft.com/mapi/proptag/0x003F0102"
Private Function GetReply(olMailItem As MailItem) As MailItem
Dim conItem As Outlook.Conversation
Dim ConTable As Outlook.Table
Dim ConArray() As Variant
Dim MsgItem As MailItem
Dim lp As Long
Dim LastVerb As Long
Dim VerbTime As Date
Dim Clockdrift As Long
Dim OriginatorID As String
Set conItem = olMailItem.GetConversation
OriginatorID = olMailItem.PropertyAccessor.BinaryToString(olMailItem.PropertyAccessor.GetProperty(PR_RECEIVED_BY_ENTRYID))
If Not conItem Is Nothing Then
Set ConTable = conItem.GetTable
ConArray = ConTable.GetArray(ConTable.GetRowCount)
LastVerb = olMailItem.PropertyAccessor.GetProperty(PR_LAST_VERB_EXECUTED)
Select Case LastVerb
Case EXCHIVERB_REPLYTOSENDER, EXCHIVERB_REPLYTOALL, EXCHIVERB_FORWARD
VerbTime = olMailItem.PropertyAccessor.GetProperty(PR_LAST_VERB_EXECUTION_TIME)
VerbTime = olMailItem.PropertyAccessor.UTCToLocalTime(VerbTime)
Debug.Print "Reply to " & olMailItem.Subject & " sent on (local time): " & VerbTime
For lp = 0 To UBound(ConArray)
If ConArray(lp, 4) = "IPM.Note" Then
Set MsgItem = ns.GetItemFromID(ConArray(lp, 0))
If Not MsgItem.Sender Is Nothing Then
If OriginatorID = MsgItem.Sender.ID Then
Clockdrift = DateDiff("s", VerbTime, MsgItem.SentOn)
If Clockdrift >= 0 And Clockdrift < 300 Then
Set GetReply = MsgItem
Exit For
Case Else
End Function
Public Sub ListIt()
Dim myOlApp As New Outlook.Application
Dim myItem As Object
Dim myReplyItem As Outlook.MailItem
Dim MyFolder As Folder
Dim xlRow As Long
'Application.ScreenUpdating = False
Set ns = Outlook.GetNamespace("MAPI")
'Set ns = myOlApp.GetNamespace("MAPI")
'Set MyFolder = ns.GetDefaultFolder(olFolderInbox)
Set MyFolder = ns.PickFolder
xlRow = 3
For Each myItem In MyFolder.Items
If myItem.Class = olMail Then
Set myReplyItem = GetReply(myItem)
If Not myReplyItem Is Nothing Then
PopulateSheet ActiveSheet, myItem, myReplyItem, xlRow
xlRow = xlRow + 1
Else: PopulateSheet ActiveSheet, myItem, myReplyItem, xlRow
xlRow = xlRow + 1
DoEvents
'Application.ScreenUpdating = True
'MsgBox "Done"
Private Sub PopulateSheet(mySheet As Worksheet, myItem As MailItem, myReplyItem As MailItem, xlRow As Long)
Dim recips() As String
Dim Recipients As Outlook.Recipient
Dim lp As Long
With mySheet
.Cells(xlRow, 1).FormulaR1C1 = myItem.Sender.PropertyAccessor.GetProperty(PR_SMTP_ADDRESS)
.Cells(xlRow, 2).FormulaR1C1 = myItem.Subject
.Cells(xlRow, 3).FormulaR1C1 = myItem.ReceivedTime
.Cells(xlRow, 4).FormulaR1C1 = myItem.Categories
.Cells(xlRow, 5).FormulaR1C1 = myReplyItem.Sender.PropertyAccessor.GetProperty(PR_SMTP_ADDRESS)
For lp = 0 To myReplyItem.Recipients.Count - 1
ReDim Preserve recips(lp) As String
recips(lp) = myReplyItem.Recipients(lp + 1).Address
.Cells(xlRow, 6).FormulaR1C1 = myReplyItem.To
.Cells(xlRow, 7).FormulaR1C1 = myReplyItem.CC
.Cells(xlRow, 8).FormulaR1C1 = myReplyItem.Subject
.Cells(xlRow, 9).FormulaR1C1 = myReplyItem.SentOn
If .Cells(xlRow, 5).Value = "" Then
.Cells(xlRow, 11).FormulaR1C1 = "=Now()-RC[-8]"
.Cells(xlRow, 11).NumberFormat = "[h]:mm:ss"
.Cells(xlRow, 10).FormulaR1C1 = "=RC[-1]-RC[-7]"
.Cells(xlRow, 10).NumberFormat = "[h]:mm:ss"
Sub FolderPicker()
Dim objNS As Namespace
Dim objFolder As Folder
Dim MyWb As Workbook
Set MyWb = ActiveWorkbook
'Set Outlook Object
Set objNS = Outlook.GetNamespace("MAPI")
Set objFolder = objNS.PickFolder
Public Sub PickOutlookFolder()
'Microsoft Outlook XX.X Object Library is required to run this code
'Variable declaration
Dim strFolderPath As String
Dim strEntryID As String
Dim strPick As String
'Set Outlook Object
AppActivate Application.Caption
If TypeName(objFolder) <> "Nothing" Then
strFolderPath = objFolder.FolderPath
strEntryID = objFolder.EntryID
strPick = objFolder.Name
'Show the selected folder details on Excel sheet
Sheet1.Range("B6").Value = strFolderPath
Sheet1.Range("C6").Value = strEntryID
Sheet1.Range("C7").Value = strPick
'Close the objects
Set objFolder = Nothing
Set objNS = Nothing
MsgBox ("Done")
niton
Exchange Server 2010
On Error Resume Next = Fail mysteriously when I do not know how to use it.
If you remove the two instances of On Error Resume Next when you run the code on the Inbox you will see any errors that were being hidden. Once fixed you would run the code on the shared mailbox and see any different errors that were being hidden.
Billy C
Thanks for responding
I have removed the On Error Resume and get the following at debug
niton
I generated an error where there was a shared mailbox.
If you did not use File | Add Account, try this with new profile. There was no error there.
Billy C
Sorry to be a pest but I don't understand what you are telling me. Could you please highlight the wrong code and insert correct code in the txt file attached. Much appreciated
  • Outlook VBA.txt
S Excel VBA and shared calendar issue Outlook VBA and Custom Forms 4
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
B Clear Offline Items (Mail Folder) via VBA Outlook VBA and Custom Forms 1
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
M VBA to send reminder email if no response Using Outlook 13
