Composingemails in reading pane
llama_thumper
Hi there,
Quick question - I like the in-pane option in Outlook 2016 (and aware I can switch it off, so that by default a new window pops up when composing emails - also aware I can pop out manually), however, would like to have an option button - for example, to not file an email or to file it to a different folder on sending.
Is there a way to do this?
Thanks in advance for any hints.
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
V Reading/Posting in Newsgroups Using Outlook 1
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
A Received Date None after reading Using Outlook 2
M Viewing Custom Form Fields in the Reading Pane and in Replies Using Outlook 3
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
J Reading outlook conatcts Outlook VBA and Custom Forms 1
D Getting Started - Reading attachment Outlook VBA and Custom Forms 4
J Reading E-Mails in VBA Outlook VBA and Custom Forms 1
P Spacebar when reading email Outlook Wishlist 2
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
