Folder view settings by VBA macro
I would have expected null too, but vba can be goofy - debug.print is my best friend. :)
D.Moore
Outlook 2016 64 bit
Yeah, you right! :)
May I ask your help on an another question:
I am trying to check each email in a folder, and when it has a specific subject, I need to write the TO recipient to a txt file with append to the first line, and not whole file overwrite.
I was able to get to this point:
Sub StoreFailedLogs()
 Dim i As Long
 Dim ItemsCount As Integer
 Dim objVariant As Variant
 Dim objFolder As Outlook.MAPIFolder
 Dim objItem As Object
 Dim fso As FileSystemObject
 Dim ts As TextStream
' On Error Resume Next
    Set fso = New FileSystemObject
    Set ts = fso.OpenTextFile("D:\failed_logs_email.txt", ForAppending, True)
    Set objFolder = Session.GetDefaultFolder(olFolderInbox).Folders("Logs")
    ItemsCount = objFolder.Items.Count
    If ItemsCount Then
        For i = ItemsCount To 1 Step -1
            Set objItem = objFolder.Items.Item(i)
            Set objVariant = objItem
            If objVariant.MessageClass = "IPM.Note" Then
                If objVariant.Subject = "Undeliverable: Logs" Then
                    With ts
                        .WriteLine (objVariant.To)
                        .Close
                    'objVariant.Delete
 Set objFolder = Nothing
 Set objVariant = Nothing
 Set objItem = Nothing
 Set ts = Nothing
 Set fso = Nothing
My problem is according to the debug: "User-defined type is not defined" indicated for FileSystemObject.
I was searching to find a better example, but those create object examples i found all failed, and seemed to be way more complicated than th actual task would require it.
Could you help me please, what would be the simplest way to make it work ?
Many many many thanks in advance!
You need a reference to the Microsoft Scripting Runtime in Tools, references.
or use this format:
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
FQIW, its generally faster to set the reference first, but on a small macro it probably wont make a difference.
D.Moore
Outlook 2016 64 bit
THANK YOU! I was able to work it out based on your help as follows:
 Dim objFSO
Dim objTextFile
Set objFSO = CreateObject("Scripting.FileSystemObject")
    Const ForAppending = 8
    Set objTextFile = objFSO.OpenTextFile("D:\emails.txt", ForAppending, True)
It is working, BUT I had to realize (and learn), that mailer-daemon failed delivery messages are not mail items, but report items.
I can read the subject as: objVariant.Subject
BUT,
my problem is, that I cannot access the original recipient, in spite, outlook shows it in the email item To column.
May I ask if there is any way to read out the original recipient to whom the email were trying to sent ?
BIG thank you for your time and kind help!
D.Moore
Outlook 2016 64 bit
The email address is indeed in the message body (left bottom arrow), BUT the reason why I was looking for to catch the original sender TO address, as I was surprised to see, that the original address is available in outlook view pane TO column (top right arrow). So, if outlook has it, I am hoping we can have it to. What do you think/suggest ?
I'll have to check on that - i hadn't noticed the address in the To field - I thought it had my address in the to field.
D.Moore
Outlook 2016 64 bit
I was surprised too, when I realized, that addition to the body, it also has it in outlook To column. I even tried a "dirty trick" to execute a reply (objVariant.Actions.Item(1).Execute) and trying pick the address up from the to Address field (.Recipients.Item(1).Address), but it only gave me the MAILER-DAEMON email address.
Maybe outlook is just intelligent and since the original recipient email address is in the body, why it is shown in the TO column of outlook reading pane ?
BTW: this is my outlook reading pane columns, it self setup:
So, in our case as you can see in my earlier message, FROM column is my email provider: MAILER-DAEMON , TO column is the original recipient email address, what I am trying to save.
I used MFCMAPI to export an NDR message - it's in PR_ORIGINAL_DISPLAY_TO_W - this is not exposed in VBA but we can use a property accessor to get it.
XML:
 <property tag = "0x0074001F" type = "PT_UNICODE" >
  <Name>PR_ORIGINAL_DISPLAY_TO_W</Name>
  <OtherNames>PidTagOriginalDisplayTo, PR_ORIGINAL_DISPLAY_TO, PR_ORIGINAL_DISPLAY_TO_A, ptagOriginalDisplayTo</OtherNames>
 <property tag = "0x0E04001F" type = "PT_UNICODE" >
  <Name>PR_DISPLAY_TO_W</Name>
  <OtherNames>PidTagDisplayTo, PR_DISPLAY_TO, PR_DISPLAY_TO_A, ptagDisplayTo</OtherNames>
It's in some other tags, but one of those should do it.
If you use a text utility such as Notepad++ that displays XML in different colors, the body will be in a different color (orange here). We want the tags which as in blue and black (in Notepad ++ at least.)
Basics on using peorptyaccessors -
Read MAPI properties not exposed in Outlook's Object Model
This is my code that works on the selected item -
 Dim propertyAccessor As Outlook.propertyAccessor
Set objItem = Application.ActiveExplorer.Selection.Item(1)
Set propertyAccessor = objItem.propertyAccessor
Debug.Print propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x0074001F")
 strTo = propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x0074001F")
    With ts
    .WriteLine (strTo)
    .Close
 Set ts = Nothing
 Set fso = Nothing
D.Moore
Outlook 2016 64 bit
Seems it was usefull for some
    With ts
    .WriteLine (strTo)
    .Close
Set ts = Nothing
Set fso = Nothing
Seems, it was useful for somebody else too. LOL!
BIG THANK YOU from me too!!
I was able to make it work both this solution and the other one you sent earlier. Hard to tell which one is more easier, but this one is definitively faster.
I also realized, that using these scripts as base of an Outlook Rule is not a stable solution as its not always got triggered. So, now I am working on to add it as itemAdd in ThisOutlookSession.
D.Moore
Outlook 2016 64 bit
I ran into a very strange issue. When Outlook is running, and a MailItem or Report item arrives, _itemAdd event for the folder in ThisOutlookSession triggers properly. But when the message arrives e.g. over the night and I turn on outlook in the morning, rules are executed, BUT the _itemAdd event not trigger, until a new item is arrive to that folder.
May I ask why and whether possible to solve this ?
D.Moore
Outlook 2016 64 bit
May I ask if there is any way to call/trigger an _itemadd event manually from Application Startup() ?
I know it is called when new item added to the given folder, but e.g. when outlook starts, it does not get called, so I would like to call it manually. Important to say, that the (ByVal Item As Object) is not exist in this case, and it isn't a problem, as I don't utilize it in the code, however, I still have to call/trigger the event somehow.
Could you help me please how an I am able to do that?
Many Thanks,
Moore
itemadd is setup using auto startup - that sets the folder to watch. If you want to run the macro on everything in a folder, or on the first item in the folder, you can call it from the auto startup. if you want to run an item add manually, you can use a small stub macro to call it and pass the selected message to the macro.
D.Moore
Outlook 2016 64 bit
My problem is, that I don't know how to do it concretely. In details:
My code is in: Private Sub objItemsUNDELIVERED_itemAdd(ByVal Item As Object)
I tried to add this line to the Application_Startup() :
(null, because the Item is irrelevant for me in this case)
But it does not work, it seems missing the value of the Item, but when I tried to pass a mail.item, it said it is not the correct type.
So, could you help me please, how can I call a Private Sub objItemsUNDELIVERED_itemAdd manually if I dont have the Item to add ?
do you want to run the itemadd routine on all messages in the folder or only on the selected message (or first message, first nn messages, new messages in last 24 hours, etc) ?
What I would probably do is create a stub macro and call it from the auto start.
put this at the end of auto start, after the folder id'd for objItemsUNDELIVERED is set.
RunItemAdd
the create a macro named RunItemAdd:
Depending on the conditions you are using, it would be something like this.
public sub RunItemAdd()
for each item in objItemsUNDELIVERED
objItemsUNDELIVERED_itemadd item
next
end sub
D.Moore
Outlook 2016 64 bit
RunItemAdd
next
end sub
The target is to run after Outlook started right away, addition to that when its run when a new item added.
Understood, so there is no proper way to call the already existing one, but better to create a separate one.
Al clear, BIG THANK YOU!
When you start outlook, the itemadd should run on all new items put into the folder - the only exception could be if using Exchange online mode as mail is put into the folder on the server.
But, unless you move the items or mark them after processing and use an if statment, you'll reprocess everything in the folder.
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
G Outlook 2013 - Default View for Public Folder Contacts Using Outlook 1
V Macro to view Junk Email folder Using Outlook 4
M Folder View in Unread Mail Pane - Outlook 2003 Using Outlook 6
B set deafult view in public folder for all users from outlook 2010 64bit Using Outlook 0
M Public folder view Using Outlook 1
C Can't see new email in inbox until view is changed or another folder is selected. Using Outlook 2
L Outlook 2007 slow to switch view from one folder to another Using Outlook 8
C Outlook 2007 Menu Bar "View" One Folder has Drop Down Box with "Arrange By", One Does Not Using Outlook 14
T Outlook 2010 / SBS 2010 - User cannot view emails moved to a folder that was previously imported fro Using Outlook 6
A Outlook 2010: Conversation view does not show messages that are in a folder. Using Outlook 4
T 'Other' calendar view not displaying public folder some times Using Outlook 1
A How do I view 'All Tasks' in outlook, regardless of the task folder it is in? Using Outlook 3
E Bcc Field Present but unpopulated in senders folder view Exchange Server Administration 7
T Outlook 2003 - View Filter apply by default on new mailbox folder Using Outlook 2
N Outlook 2007 does not refresh view when moving mail to a folder Using Outlook 1
N IMAP emails not automatically downloading when view and not purging after deleting and then purging folder Using Outlook 1
N Mail folder view properties Using Outlook 2
R Outlook 2010 Public Folder Home Page view Using Outlook 9
M How to add a message to a mapi view folder Outlook VBA and Custom Forms 1
R copying a custom view from a public folder and distributing programatically Outlook VBA and Custom Forms 3
Y View Reading Pane for Drafts folder Using Outlook 2
G How to add a folder shortcut to outlook quick access toolbar? Using Outlook 3
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 0
B Spam folder not showing in Outlook Using Outlook 5
J Moved many emails to Outlook external folder, need to delete on Gmail server Using Outlook 13
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
J Moving Imported folder Using Outlook 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
B Outlook 365 - Folder pane list clears Using Outlook 24
R Folder pane width change Using Outlook 54
T Missing Folder in Outlook.com Using Outlook 3
