Possible to hide ribbon with custom appointment form?
ajkessel
Outlook 2016 64 bit
I want to always have "required attendees" appear when I create a new appointment, without having to switch to the scheduling assistant or select "invite attendees." The only way I've figured out to do so is create a new custom form with that field in the template. (Let me know if there is a better way to do it).
The problem I'm having now is when I switched to the new custom form for my default appointment item, the ribbon always appears, even if I hit CTRL-F1 to toggle it. Is there any way to use a different appointment template yet not show the ribbon when creating a new item?
A side question is whether it's possible to have a separate picker for the date and picker for the time with a custom appointment form, but I'm guessing that's not possible based on other forum postings. Let me know if I'm mistaken about that.
ajkessel
Outlook 2016 64 bit
Related question I meant to include above: when I'm making a custom appointment form, is there any way to start with the default page so it doesn't need to be recreated from scratch? The default page cannot be edited but can it be duplicated/copied somehow?
I'm noyt sure on the ribbon problem, but on the picker - unless you are using custom controls, you are limited to what outlook includes.
No on duplicating...
Do you want the appointment form to always open as a meeting? Ctrl+Shift+Q is the keyboard shortcut or you could use a macro to always use a meeting form.
ajkessel
Outlook 2016 64 bit
Thanks--I wasn't aware of Ctrl+Shift+Q, that gets me most of what I was looking for. I also wrote some VBA to pre-populate the form which achieves the rest.
T Is it possible to hide a mailbox but still send on the behalf of. Exchange Server Administration 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Calendar Printing Assistant 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
N Citrix installation possible? BCM (Business Contact Manager) 1
D Is it possible to set up an email rule for a user based on alias address? Exchange Server Administration 3
K Possible to have a calendar which defaults to no reminder? Using Outlook 3
T Removing time zone setting from an appointment / meeting: is it possible? Using Outlook 2
K Is it possible to sync IPhone to BCM Outlook contact, calendars ... all data? BCM (Business Contact Manager) 16
