Prevent connection to Public Folders on Exchange?
AndrewWeb
Outlook 2013 32 bit
I would like to avoid trying to connect to public folders in my Outlook 365 (Version 1809, Build 1082.80181 Click-to-run). I saw a way to do this in older setups, which involved creating a 0-valued HasPublicFolders key in the registry under "HKEY_CURRENT_USER\Software\Microsoft\Exchange\Setup". But it seems that this registry key is no longer around.
The autodiscover.xml that my outlook gets from the exchange server is trying to connect me to a public folder to which I don't have access, so I keep getting prompts for credentials to connect. I asked my IT team about it, and they just wanted me to make sure I didn't have an extra profile for that public folder (which I didn't). I've done repairs, uninstall/reinstall, etc., but the phantom public folder credential prompts keep coming back. Is there a way to tell outlook not to look for those folders? Worst case, I guess I could turn off autodiscover, edit that xml file to remove the reference to the public folder. Any other ideas?
AndrewWeb
Outlook 2013 32 bit
Apologies: I meant to say that under my "Exchange Account Settings", I have "Cached Exchange Mode" checked, but have always unchecked the options for "Download shared folders" and "Download Public Folder Favorites"
As far as I know, you can't block PF in current versions. You can try adding the Setup key and adding that value to it - i tried it, but its not working. However, it might only work if you add the account after setting the key.
O How to prevent CC from showing when creating a new mail? Using Outlook 1
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Multiple mailboxes, 1 certificate. How to prevent message "Invalid Certificate" Using Outlook 0
S How to prevent addins Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery New Slipstick.com Articles 0
evdbogaard How to prevent extra line feeds in replies Using Outlook 3
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
oj43085 Prevent Outlook from blocking image from a single source Using Outlook 4
I How to prevent exchange email account from sending emails in Outlook Using Outlook 4
D Prevent Outlook from resolving incomplete contact when clicking send Using Outlook 2
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
B Item_Write = False don't prevent custom form from closing Using Outlook 1
N Allow Another User to Send on Behalf of But Prevent Access to Inbox Using Outlook 4
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
M Links prevent sending email Using Outlook 3
S How to Prevent of using CC field Using Outlook 1
D Received emails show only red X's no images - Email set for HTML. Prevent download of images is OFF Using Outlook 6
D Images showing up as X's in Outlook 2003 emails. Outlook is set to HTML and Prevent Picture downloa Using Outlook 2
V Prevent appointments not yet accepted from showing up in Calendars Using Outlook 3
B Prevent changing of appointment time or date by other users Using Outlook 1
C Prevent clients outlook anywhere URL from being changed by autodiscover? Using Outlook 4
L Prevent Exchange from becoming default account on Windows 7 Using Outlook 5
K How to prevent that Outlook is sending before my add-in is finished? Outlook VBA and Custom Forms 5
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
C Prevent Outlook from sending an email with a blank Subject Line Outlook VBA and Custom Forms 3
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
Z Prevent Changes to Custom Form Outlook VBA and Custom Forms 1
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
