Question
NACCACHE
Hi...is the (mapisvc.inf) necessity for Outlook 10...if yes how I can download it in my Outlook...
My Office Professional 2010 64-bit.
BR.
NAC
NACCACHE
BR.
NAC
Can I make Repair from the Office 10 CD...in order re-download the (mapisvc.inf) ?
NACCACHE
NACCACHE
Thanks for your message.
I installed recently the legal MS Office 10 in my used Laptop (it was for my cousin, its OS Windows 7 Home Premium, 64-bit.
Yes I see error message...and I can't Add new Outlook Data Files...
How I can send you the PrintScreen of error?
Use prntscrn key (I think Alt+prntscrn key will get just the active window (or ctrl :)) then click the picture icon here and you should be able to paste into it the body here - if not, you can save it as a file and insert it.
NACCACHE
I hate useless error messages. :) Check in Event Viewer to see if it has any more information on it.
Yeah, the file explorer path is the correct location for the mapi inf.
From the looks of this from an office 2010 install, the file only holds addin info, not the other mapi services it used to hold. I hadn't realized that the connector was still installed - it hasn't worked with outlook.com in years - and when i removed that and restarted outlook, mapisvc.inf was updated - only BCM and iCloud remain in it.
[MAPI]
ServiceOrder=
[Services]
MSN_CON=Microsoft Outlook Hotmail Connector
IrisMS=Business Contact Manager Database
APLZODSERVICE=iCloud
[Default Services]
[MSN_CON]
PR_SERVICE_DLL_NAME=MSNCON.DLL
PR_DISPLAY_NAME=Microsoft Outlook Hotmail Connector
PR_RESOURCE_FLAGS=SERVICE_PRIMARY_IDENTITY|SERVICE_NO_RESTART
PR_SERVICE_ENTRY_NAME=ServiceEntry
PR_SERVICE_DELETE_FILES=MSNCON.DLL
PR_SERVICE_SUPPORT_FILES=MSNCON.DLL
Providers=MSN_AB,MSN_MS,MSN_XP
[IrisMS]
PR_RESOURCE_FLAGS=SERVICE_SINGLE_COPY
Providers=Iris_MS
PR_SERVICE_DLL_NAME=BCMMS.DLL
PR_SERVICE_ENTRY_NAME=IrisServiceEntry
[APLZODSERVICE]
PR_SERVICE_DELETE_FILES=C:\PROGRA~2\COMMON~1\Apple\INTERN~1\APLZOD.dll
PR_SERVICE_DLL_NAME=C:\PROGRA~2\COMMON~1\Apple\INTERN~1\APLZOD.dll
PR_SERVICE_SUPPORT_FILES=C:\PROGRA~2\COMMON~1\Apple\INTERN~1\APLZOD.dll
PR_DISPLAY_NAME=iCloud
PR_RESOURCE_FLAGS=SERVICE_NO_PRIMARY_IDENTITY|SERVICE_SINGLE_COPY
PR_SERVICE_ENTRY_NAME=APLZODServiceEntry
Providers=APLZODMP
[MSN_AB]
PR_PROVIDER_DISPLAY=Microsoft Outlook Hotmail Connector
PR_RESOURCE_FLAGS=STATUS_PRIMARY_IDENTITY
PR_RESOURCE_TYPE=MAPI_AB_PROVIDER
PR_PROVIDER_DLL_NAME=MSNCON.DLL
[MSN_MS]
PR_RESOURCE_TYPE=MAPI_STORE_PROVIDER
PR_RESOURCE_FLAGS=STATUS_DEFAULT_STORE|STATUS_PRIMARY_IDENTITY|STATUS_PRIMARY_STORE
PR_PROVIDER_DISPLAY=Outlook Hotmail Connector Store Service
[MSN_XP]
PR_RESOURCE_TYPE=MAPI_TRANSPORT_PROVIDER
PR_PROVIDER_DISPLAY=Outlook Hotmail Connector Transport Service
[Iris_MS]
PR_PROVIDER_DLL_NAME=BCMMS.DLL
PR_RESOURCE_FLAGS=STATUS_NO_DEFAULT_STORE
PR_PROVIDER_DISPLAY=Business Contact Manager Database
PR_MDB_PROVIDER=4B4506EEF0B1A147AA0557297D0A084A
[APLZODMP]
PR_PROVIDER_DLL_NAME=C:\PROGRA~2\COMMON~1\Apple\INTERN~1\APLZOD.dll
PR_PROVIDER_DISPLAY=iCloud
NACCACHE
Thanks for your support.
Do you mean that the "mapisvc.inf" program is not necessary now for Outlook2010?
Best regards,
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
D a general question regarding data files Using Outlook 3
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
A Newb-ish question Using Outlook 2
A The hardest VBA/Outlook question yet Using Outlook 1
S DAG question Exchange Server Administration 0
P Outlook File Extension Question Using Outlook 3
J Outlook 2010 Calendaring Question Using Outlook 0
K Syncing outlook with iCloud question Using Outlook 5
T Outlook Prf/Automation question Using Outlook 2
T Settings question Using Outlook 6
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
IGWright Outlook 2013 .pst Question Using Outlook 10
F To Do Bar question Using Outlook 1
T I recently changed my pop3 email to an imap - question on folders Using Outlook 3
e_a_g_l_e_p_i Can someone please answer a question about tasks for me Using Outlook 2
S Question regarding contact links Exchange Server Administration 37
J resource calendar mailbox email question Exchange Server Administration 1
D Outlook Security Question Using Outlook 3
T Manage Rules question Using Outlook 1
C a BCC script question Using Outlook 1
S too difficult of a question to google Using Outlook 2
M Outlook custom form question Using Outlook 4
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
