Using field names to capture a data element
Mize
Outlook 2016 64 bit
I'd like to know if I can automatically capture/display the following data element from an outlook 2016 desktop email without performing a manual lookup via Internet Headers? While I researched the potential displays, I didn't see anything that fit this field description.
Authentication-Results: spf=none (sender IP is =xxx.xx.xxx.xx)
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
M I get a result of None when I add a field using Last Verb Execution Time Using Outlook 4
O How to paste website content using a specific font and removing URLs Using Outlook 2
