VBA Code in Outlook disappears after first use
acuLee
I have a simple VBA code in Outlook 2016 that pops up when users send an email that does not contain our domain name.
This works fine on a local machine using a local profile but when I transfer the code to accounts in a Citrix environment the code works only once and then disappears and does not work.
I can copy the code into the Visual Basic area of Outlook and click save, theVbaProject.OTM file updates in the %AppData%\Roaming\Microsoft\Outlook directory
But if i close down outlook and open again the code is not there but the v.OTM file is still there.
If i log out and log back on again the code appears again, I can use this one time and then again the code disappears.
Any ideas?
I'm assuming, since the macro works once, that this a typo %AppData%\Roaming\Microsoft\Outlook.
That path goes to C:\Users\%username%\AppData\Roaming\Roaming\Microsoft\Outlook - use %AppData%\Microsoft\Outlook
Sounds like its not saving the changes or is not syncing the changes back to the roaming directory.
I don't know if using a different VBA project would help - see Start Outlook using a different VBA Project file
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
S ThisOutlookSession in VBA not there anymore and code is gone Using Outlook 2
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
N VBA code to show today's date + a sequencial number in subject lin Outlook VBA and Custom Forms 1
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
F Recovery of VBA code Outlook VBA and Custom Forms 2
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
B how/what dialog boxes can I display from VBA code Outlook VBA and Custom Forms 1
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
