Indexing Problems Outlook 365
Mitchell
I have tried to re-index outlook several times and failed. Particularly problematic is Contacts. It seems that Mail is indexed OK in the Inboxes, but not the PSTs too. I have several emails handled by Outlook, including Exchange, 363 and Outlook.com. Is there an instruction sheet that can walk me through the correct way to reindex?
is the pst enabled for indexing? In search tools, locations to search, is the pst listed?
Mitchell
Hi Dianne,
Thank you so much for getting back to me. I didn't find your screenshot. Here is what I have for searches, including under Indexing Options:
Any other recommendation?
Mitchell
O Indexing Using Outlook 7
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
witzker Has Outlook 2010 to be opened for Indexing Win7 Using Outlook 1
M Constant indexing/no search function Using Outlook 0
Y Outlook indexing items increasing, indexation never finishes Using Outlook 1
J Indexing - one user a week - indexing breaks. Using Outlook 1
E Does Outlook indexing work across multiple servers? Using Outlook 0
S Search Indexing (Copying Folders) Using Outlook 0
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
