How to apply view settings on all accounts and folders
ofw62
Today changed to IMAP (used good old POP3).
A result is that all settings are gone. Within each and every mailbox the columns are defaulted, preview is enabled, etc.
And of course tasks are gone, rules are gone.
Is there a way to apply view settings overall?
Or, hopefully, at least for all folders within one account.
MS_Outlook
Outlook.com (as MS Exchange)
It looks like you are reconfigured your email account as IMAP which is totally different protocol when compared to POP3. Not possible to get the settings back in new setup. You may have to manually redo the settings in new setup.
Taking backup is always preferred in these kind of scenarios. Here is the link which may help: Export or backup email, contacts, and calendar to an Outlook .pst file
ofw62
I have no problem setting view a few times, but with a number of accounts with a number of folders each account, it is boring to change it for each and every folder...
Probably that is how Outlook works: just 'set and apply to all folders' is too easy, you have to do it the hard way, with hundreds of clicks...
Regretfully so.
MS_Outlook
Regretfully so.
Yes, this is how Outlook is by design. Set and Apply to folders still works for you.
ofw62
Solution:
1. go into view, select columns you wish
2. then (in view) left hand top corner, click on"Change View", then "Apply view to other mail folders"
JoJo
Outlook 2016 64 bit
Goodness. First, I spent 4 hours (FOUR HOURS) on the phone with Microsoft Support 2 days ago, trying to get them to help me because I couldn't get the VB editor to open in Outlook 365 desktop. They transferred me back and forth (some didn't even know what VB is!) and eventually told me I'd have to pay them $500 to open a help ticket. I hung up, more frustrated than I can put into words.
Then my husband wandered in & figured it out in 10 seconds (my WhatsApp was blocking it; solution: turn off WhatsApp & open Outlook, then turn WhatsApp back on--at least until I figure out how to add it as an exception in WhatsApp). (Sidenote: I'd love to call MS and offer them the solution--for $500!)
Then I set out trying to figure out how the heck to write a macro for Outlook to set a particular email folder view to all my other email folders (the whole reason I was doing all of this)--my experience with VBA programming has been limited mainly to Word and some Excel, and even then, it's been years. (At one point, I had the most popular "VBA code samples" page on Google! But this was 20 years ago.) So, I purchased a book from Amazon. I went online to MS's site and found the Outlook objects and so on. And there I sat. I have absolutely no familiarity with Outlook objects and I had no idea where to start.
Yesterday evening, a friend told me about this forum. I came here and BAM! Here's the answer. I didn't even need to write a macro. Just did the above (apply view to other folders). Cripes. All this angst for nothing (except that it got me interested in doing more VBA programming, which I always enjoyed)!!!
THANK YOU!!!!!
misha
Exchange Server 2013
Ithink its hijacking alt+f11
R Apply a category to item in inbox view Outlook VBA and Custom Forms 1
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
Diane Poremsky Use Word Macro to Apply Formatting to Email New Slipstick.com Articles 0
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
Diane Poremsky Apply Outlook Stationery to Replies and Forwards New Slipstick.com Articles 0
B Apply two rules on one email Using Outlook 2
R Rules - apply to messages > n days old Using Outlook 2
B Unable to apply rule on Exchange server functional account Exchange Server Administration 1
M Apply different views to calendars Using Outlook 0
C Apply Category Color for Appointment Background Color Calendar Printing Assistant 2
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
T Is there a way to apply a macro before a signature is applied in email? Using Outlook 1
K Why doesn't a rule apply to a friendly name? Using Outlook 2
L Unable to apply SP1 to Exchange 2010 Exchange Server Administration 5
T -basefolderonly still apply when creating a new retention policy in Exchange 2010/sp1? Exchange Server Administration 6
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
J Weekend View in Calendar Using Outlook 1
B See "Change View" Drop Down as a List? Using Outlook 1
B How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Calendar Printing Assistant 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
