How can I increase/faster outlook VBA Macro Speed ?
nbm1515
Outlook 2016 64 bit
Can someone help me with following code to increase/faster outlook VBA Macro Speed ? Currently It taking lot of time run all email rules and getting process slow.
Sub RunAllInboxRules()
Dim st As Outlook.Store
Dim myRules As Outlook.Rules
Dim rl As Outlook.Rule
Dim count As Integer
Dim ruleList As String
'On Error Resume Next
' get default store (where rules live)
Set st = Application.Session.DefaultStore
' get rules
Set myRules = st.GetRules
' iterate all the rules
For Each rl In myRules
' determine if it's an Inbox rule
If rl.RuleType = olRuleReceive Then
' if so, run it
rl.Execute ShowProgress:=True
count = count + 1
ruleList = ruleList & vbCrLf & rl.Name
' tell the user what you did
ruleList = "These rules were executed against the Inbox: " & vbCrLf & ruleList
MsgBox ruleList, vbInformation, "Macro: RunAllInboxRules"
Set rl = Nothing
Set st = Nothing
Set myRules = Nothing
Michael Bauer
In general the performace is better if you forego the progress dialog. Instead, simply display a MsgBox when done. Also, joining the rulelist string could take one or more seconds for 1000 loops. Since you run all rules, why not just say that instead of listing all the rule names?
J Increase font size of message body Using Outlook 5
C Increase Outlook 2013 message window row height Using Outlook 2
O How to increase Font size in Outlook 2013 Using Outlook 1
A OL 2007 problem - sudden large increase in message size Using Outlook 12
M Increase "Move To" List Length Using Outlook 3
J Can't Increase Outlook 2007 PST size Using Outlook 2
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 9
@ Outlook Using Outlook 2
