Double line spacing - solved with minor drawback
ofw62
On Internet there are numerous threads on the issue of double line spacing when sending mails to Gmail back and forth.
I had a macro running to solve that. Though the macro is still in place, after changing to Office 365, it stopped working.
see: Run macro automatically at sending an email
Don't know why, nothing has changed. Sadly, I could not get it working again.
Found a relatively simple solution to get rid of the double line spacing.
Outlook -> File ->Options -> Mail -> go down to "Message format"
Deselect option "Use Cascading Style Sheets (CSS) for appearance of messages"
Drawback - the thin line, serving as message separator, is removed, regretfully so.
(probably there is no way to avoid that)
Attached example of sending an email from Outlook to Gmail, back and forth
M Outlook 2016 IOS recipients receive my paragraph double space as quadruple space Using Outlook 2
T Double clik behavior on agenda open a new meeting request Using Outlook 1
Reji Rajan Double spotting Outlook VBA and Custom Forms 2
S Changing Double-Space Default When Replying To Emails Using Outlook 2
Y How do you stop double booking? Using Outlook 1
P double emails Using Outlook 1
F Public calander double booking Using Outlook 1
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
R Stop Double Booking Rooms Using Outlook 3
E Double clicking on from email address does no longer open corresponding contact in Outlook 2007 Using Outlook 7
J Macro to open email (like double click) in Outlook Outlook VBA and Custom Forms 4
2 How to get rid of the "Emailing:" prefix in the subject line Using Outlook 1
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
C Outlook - cannot save subject line changes Using Outlook 2
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
J Marco in search of text in subject line Using Outlook 8
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
Harald Olsen Automated insertion of address in address line Using Outlook 1
P Can't see full text in From and Subject line Using Outlook 1
D dropdown list in new email in subject line Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
I Make a macro in line rather than pop out Outlook VBA and Custom Forms 0
Diane Poremsky Editing the Subject Line in Outlook Using Outlook 0
Aussie I Change the Subject Line ... but after it is moved the subject has reverted Using Outlook 1
Diane Poremsky Add a file number or keyword to the subject line of messages Using Outlook 0
