Project Management - Adding Folders for Different Folder Types
esemm
Outlook 2016 64 bit
Is there a way to create a folder and then beneath that folder create an email type folder and task type folder so that both sub folders can be seen under the top folder? It looks like you can only see a task folder in the task tab. I would like to have them be all together similar to the way an Explorer structure would show them.
Top folder
Email Folder
Task Folder
If it can't be done out of the box are there any 3rd party products available that can mimick this behavior?
Thank you,
Elliot Semmelman
Diane Poremsky Project and Business Process Management Tools Using Outlook 0
C Project Management and Communication History BCM (Business Contact Manager) 2
wallisellener Marketing and Project Management field are not displaying BCM (Business Contact Manager) 2
T link multiple emails to one project in one way BCM (Business Contact Manager) 1
P Autopopulate Email Subject from Project BCM (Business Contact Manager) 6
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
T sequential project numbers in Business Contact Manager BCM (Business Contact Manager) 2
M How do I get the version number of the Setup project? Outlook VBA and Custom Forms 1
E trust access to visual basic project greyed out in outlook 2003 Outlook VBA and Custom Forms 1
S O2K vbe error message "Can't find project or library"? Outlook VBA and Custom Forms 3
C All my projects and project tasks are gone - OL BCM 2007 BCM (Business Contact Manager) 2
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
J No setup project with Outlook 2007 Add-In project Outlook VBA and Custom Forms 16
M Adding another add-in to a project Outlook VBA and Custom Forms 1
J Can I link a single project to multiple accounts / business contac BCM (Business Contact Manager) 1
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
D Microsoft Exchange account - Remote management Using Outlook.com accounts in Outlook 1
S Active Directory Management Tools for Administrators Using Outlook 0
M Data File Management confusion after migration Using Outlook.com accounts in Outlook 1
D Outlook Add-on for Exchange Spam Management? Exchange Server Administration 2
Diane Poremsky Customer Relationship Management (CRM) Utilities Using Outlook 0
mikecox date file management Using Outlook 10
S Signed/encrypted email management Using Outlook 4
H Disaster. Management wants to change email format. Exchange Server Administration 9
S Exchange Management Shell closes on command failure Exchange Server Administration 5
R Data File Management Using Outlook 1
J Just contact management without the sales and marketing features? BCM (Business Contact Manager) 1
L Exchange Management Console - Initializtion failed on Logon Failure: unknown username or bad passwor Exchange Server Administration 4
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
