Read and Write to Text File
Alan McGowan
Outlook 2013 64 bit
I have created a macro that I use to batch save emails in MSG format to specific folders on a server. At present the folder paths are held in a spreadsheet and displayed on a userform where you can pick which folder to use. I've noticed recently that the macro is running very slowly and I suspect the issue is due to Excel opening slowly in the background when the macro reads from the spreadsheet. I was wondering if using a simple text file would be quicker? and also then wondering how you would go about reading specific values from a text file and on a similar note how you would write the values to the text file as I have another userform where you can edit the folder list held in the spreadsheet without having to open the spreadsheet directly i.e. you can do it all within Outlook. Any thoughts?
Alan McGowan
Outlook 2013 64 bit
Having thought about it some more what I think I really need is a way to read a csv file and populate a listbox. It would also be good to be able to add to the csv file from textbox's on a userform but this is less essential at the present time.
S Outlook 2010 hang on read/write Using Outlook 3
P unable to write mail, able to read Using Outlook 0
V Outlook 2007: How to read/write Out-of-Office settings Outlook VBA and Custom Forms 3
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
e_a_g_l_e_p_i Is it possible it set the fonts used to read incoming mail Using Outlook 11
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments New Slipstick.com Articles 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
J From column changes when message is read Using Outlook 1
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
S Duplicate Read Receipt Using Outlook 4
K Read, unread, i'm losing clients! Using Outlook 1
H mark as read per folder options Using Outlook 1
G Editing the Read Receipt Using Outlook 1
S Block read receipt when outlook is configured to Exchange server Using Outlook 0
