Wierd Office 365 Contact unable to edit body of random contacts
Len Raphael
Outlook 2016 64 bit
Not happening in the portal Outlook only local Outlook 365. Creating new profile on same or different machine and safe mode doesn't fix the problem.
on the contacts that it occurs, one can edit all the other fields but not the main body.
latest monthly release, Win 10.
Len Raphael
Outlook 2016 64 bit
as of a few days ago at least, it's a known issue to MS. Maybe the next monthly release will fix.
misha
Exchange Server 2013
I also faced the same issue so I directly communicate with Microsoft.
Len Raphael
Outlook 2016 64 bit
MS never came out with a fix. But the most straight forward fix is to delete current profile and search for the ost file on every machine. Then create a new profile. That presumedly? brings down a clean copy of what's in the cloud. Haven't had the problem recurr.
(supposedly deleting a profile, deletes the ost file. But I searched local pc after deleting profile, and the ost was still there. Maybe it's supposed to get overwritten, but for this problem merely deleting profile was not sufficient.)
misha
ok thank you Len Raphael for your help
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S office 2016 pop3 Using Outlook.com accounts in Outlook 3
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
O Office 365 Outlook - mark to download Using Outlook 0
T O365 and Office Message Encryption Exchange Server Administration 2
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
L Office 365 cloud based rules Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
O Backup Office settings - registry key Using Outlook 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
J Out of Office, Delegate Using Outlook 1
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
B Search function in Office 365 has stopped working Using Outlook 3
L Outlook Office 365 cached mode crashing Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
