Outlook to check for specific text
sem
Outlook 2016 64 bit
Dear All,
While sending an email I need a outlook code to check a specific text in the body line and if found it do not send the email and just pop up the number of times the text found in the email.
Is it possible to derive a code for this ?
sem
Outlook 2016 64 bit
anyone who can help me on this...
Dan_W
Outlook.com (as MS Exchange)
Hi Sem
The Slipstick website helpfully has the answer for you, in parts. First, check out the "Checking for missing attachments before sending a message" article. Here, you will see the following code snippet:
   If InStr(1, Item.Body, "attach", vbTextCompare) > 0 Then
        If Item.Attachments.Count = 0 Then
          answer = MsgBox("There's no attachment, send anyway?", vbYesNo)
          If answer = vbNo Then Cancel = True
The important part of the code is If InStr(1, Item.Body, "attach", vbTextCompare) > 0 Then. The INSTR function will check the body of the email for the word "attach"; if it finds the word, it will return the location of the character in that word within the string being search (item.body). However, this won't give you the number of instances that the search term appears in the email body. You would need to add more code if you wanted to use this approach.
Second, an alternative approach would be to use regular expressions to parse the body of the email. You should look at "Use RegEx to extract text from an Outlook email message". I would suggest putting your code in the Application_ItemSend event, as above, then using the RegEx test method to see if the word/phrase exists in the email body. If it does, then execute the regex, and get the number of matches.
I hope that helps.
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Custom form check if there an attachment Outlook VBA and Custom Forms 2
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
M Outlook Rules check for new line character Using Outlook 1
G Outlook rule check for messages not received Outlook VBA and Custom Forms 2
E Outlook could not create the work file. Check the temp environment variable Using Outlook 8
H out to check whether outlook configured or not Outlook VBA and Custom Forms 1
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 5
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 2
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 3
S Mac Outlook 365 Questions Using Outlook 0
M Outlook calendar is missing Using Outlook 2
T Have you written an articles about Outlook? Using Outlook 3
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
R Outlook 365 update sets delete from server flag Using Outlook 1
X Outlook automation pull from PDF Using Outlook 5
O Outlook 365 - How to create / copy a new contact from an existing one? Using Outlook 3
M Gmail address associated with Outlook on new phone Using Outlook 9
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
V Validating Outlook form with "OR" and "AND" Outlook VBA and Custom Forms 1
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
V Outlook behaving oddly Using Outlook 2
M HTML email signature in Outlook Using Outlook 1
M Respond to Outlook Email Outlook VBA and Custom Forms 0
U Outlook locking up when replying to Email Using Outlook 7
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
