Outlook 2013 Yahoo IMAP Sync problems
David U
Outlook 2013 64 bit
Over the years I have periodically had sync problems with my Yahoo IMAP email account using Outlook 2013. These problems will cause sync to hang part way through, which results in outlook being stuck in sync "processing" mode, and not delivering email, until I close and re-open Outlook. Usually I can view the sync log and resolve the problem by logging into Yahoo web mail and cleaning up whatever the problem is. Currently, with the error log below, I can't figure out what the problem is. Outlook will sync fine for a few days, and then hang up.
That attached file is a summary. Here are more details:
18:06:07 Synchronizer Version 15.0.5111.1000
18:06:07 Synchronizing Mailbox 'dungernh@yahoo.com'
18:06:07 Synchronizing Hierarchy
18:06:07 1 folder(s) updated in online store
18:07:12 Terminated in error
18:07:12 [800CCC0F-0-0-940]
15:28:42 Synchronizer Version 15.0.5111.1000
15:28:42 Synchronizing Mailbox 'dungernh@yahoo.com'
15:28:42 Synchronizing server changes in folder 'Inbox'
15:29:47 Error synchronizing folder
15:29:47 [8004DF03-0-0-560]
15:29:47 Done
I have tried forcing the root folder to INBOX, but Yahoo IMAP will not retrieve mail properly with that setting.
Where do I go from here?
David
jac11
Outlook 2016 for Mac
thanks for sharing your issue, I have a idea to solve this issue visit
Corny one liners i think you can find the proper solution here to resolve your issue quickly.
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
K Rebuilding Outlook 2013 from Outlook.com after OS rebuild Using Outlook.com accounts in Outlook 2
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
S Outlook 2013 doesn't download html messages Using Outlook 0
Gwarcyn Outlook 2013 / Address Books disappear Using Outlook 0
T Online Training for Outlook 2013 Using Outlook 0
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open New Slipstick.com Articles 0
