BCM 2013 not functioning as BCM 2010 Example no drop down for communications history
Dan11
Outlook 2013 64 bit
I recently upgraded my Outlook 2010 to Outlook 2013. I've been using Business Contact Manager in Outlook 2010 with no issues. After upgrading to Outlook 2013, Business Contact Manager is missing features and doesn't seem to function the same as in Outlook 2010. Example... the "Communications History" drop down is missing from the "Show" section in the Ribbon under "Account". Also, when viewing an account there is no longer a list of contacts associated with the account.
Please help.
Thank you,
Dan
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
L Importing Opportunities in to BCM 2013 BCM (Business Contact Manager) 0
JimR Outlook 2013 BCM not working BCM (Business Contact Manager) 3
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
SirFishAlot Send atachment with mass email using BCM, and Publisher 2013 BCM (Business Contact Manager) 1
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
J BCM 2013 in Outlook 2013 will not load BCM (Business Contact Manager) 5
B Outlook 2013 & BCM Issue Using Outlook 2
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
B bcm and "Office 365 Home Premium" 2013 BCM (Business Contact Manager) 1
O Will BCM work with any Office 2013? BCM (Business Contact Manager) 1
S BCM stops Outlook 2013 BCM (Business Contact Manager) 6
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
G "database is not compatible with BCM for Outlook 2013" & more BCM (Business Contact Manager) 0
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
O BCM 2013 Training Sources BCM (Business Contact Manager) 1
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
V BCM Use with Outlook 2013 BCM (Business Contact Manager) 42
wallisellener BCM 2013 importing contacts from CSV file BCM (Business Contact Manager) 8
wallisellener Server configuration for BCM 2013 shared database BCM (Business Contact Manager) 15
A Bcm 2013? BCM (Business Contact Manager) 13
