Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc
astro46
Outlook 2016 64 bit
Locally Installed version of Outlook in Office 2019, (not 365).
From beginning, 3 days ago, there have been problems with finding contacts. Sometimes the entire name has to be typed. This happens in 'search people' . and not finding names when typing into email To: fields. I can use drop down to select name. then it will suggest that name later. Same with entering groups.
I have the Outlook contact folder picked as default in data, and set as address book. I do not use contacts at the onedrive site.
In ver. 2016 it all worked fine.
any suggests on what settings to check?
Or am I better off going back to Office 2016? I don't know of anything that is especially better in ver 2019, only that support will continue for a few more years.
astro46
Outlook 2016 64 bit
Diane, thanks for suggestion.
I tried emptying the autocomplete. didn't help.
When I ask to check names in email To: field, it comes back with 'Outlook doesn't recognize XXXX', when I ask to show more names it always is looking in the outlook.com data file. I would have to keep switching to the .pst data file. Frankly I would like to totally remove the outlook.com data file from outlook since it has always been a source of annoyances, but it seems to be necessary using calendar, which syncs to my iphone.
perhaps the problem is outlook defaulting to the .com data file. in control panel>mail>data files I have outlook.pst set as 'default. the outlook.com file is also listed.
Jeffrey
Schendel
Outlook 2016 64 bit
Exchange Server 2013
I've noticed this as well. It's a huge step back. Do you think MS will address this in an update?
astro46
Outlook 2016 64 bit
In the past MS hasn't shown itself to be responsive to problems. They're more focused on the next sales pitch.
Our best hope is that Diane has a workaround or solution for this issue.
Open the address book, then go to it's tools > options. Set the search order to custom and arrange the contacts folders in the order of folder with the most contacts. That should solve the check names problem, although it shouldn't be a problem if the contacts folder is enabled as an address book as outlook will check every contacts folder until it finds a match (then quit searching additional address books).
astro46
Outlook 2016 64 bit
Thanks Diane. this seems to have fixed the People Search.
Still having problem with Outlook finding suggestions for names in email.
- type a name in To: field (if the name has been used previously it will appear as suggestion).
- In OL16 a red line would eventually appear under the name, allowing me to click and pick among the choices.
-Now I have to click 'check names', it then tells me 'no suggestions",
-click on "show more names" which gives a list of names with the one I want, generally right at the top.
Why isn't OL19 offering the names as suggestions in the email, as OL16 did? Is there a setting missing? Or a service that may have been turned off?
Jeffrey
astro46
Outlook 2016 64 bit
I have tried uninstalling and reinstalling office 2019.
I still do not see, when addressing an email, the red squiggly line below a newly used name, or the pop up window asking which possible name do I want to select. It only tells me 'no suggestions'.
This must be a setting, missing service, or something else, on this new computer, as I tried installing Office 2019 on laptop and it works ok there.
Thanks for any suggestions.
Jeffrey
misha
I also tried to install office 2019 but its showing error in installing it
astro46
Outlook 2016 64 bit
Seems like this is worse than i thought. Apparently not a OF19 problem. I installed OF16 and having the same issue with Outlook not being able to suggest contacts ('check names') when addressing an email. A some setting or service on this new computer? I have not been able to figure out what it is.
astro46
Outlook 2016 64 bit
in Outlook options both 'automatic name checking' and 'auto complete' are checked.
astro46
Outlook 2016 64 bit
I think that I have solved the problem. took hours of searching and trial and error. I looked again at the address book options (where diane pointed me to, above). I noticed that in addition to global address book (whatever that is?) there were 2 "contacts" address books. one was already at the top of the list. I added the second one, moved it to top of list, removed the other one. and check names started giving options. I suspect that simply adding the second address book would have fixed it. I guess global wasn't so global.
I knew that both my local email account and the outlook.com account had "contacts" named address books. I tried to rename them from several places but it wouldn't work. Obviously, if they had different names this whole problem might have been more easily solved. But confusion and inefficiency is a hallmark of microsoft. they are loath to give it up.
I have yet to see the red wavy line appear.
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
witzker Outlook 2019 is cutting Picture Extension *.pn_ Using Outlook 3
A Outlook (and Office) 2019 Logging Using Outlook 2
witzker Open Contact missing in Outlook 2019 Using Outlook 2
C All Gmails don't show in Outlook 2019 Using Outlook 2
J How do I disable advertising in Outlook 2019? Using Outlook 13
R Outlook 2019 Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
T The Linked Image Cannot Be Displayed in Outlook Using Outlook 5
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
P i-Phone 6s Plus receiving 2 notifications from Outlook email Using Outlook 1
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
