Add an Attachment Using an Array and Match first 17 Letters to Matching Template .oft to Send eMail
jag51
I've been trying to adapt Diane's code under "Use an Outlook Macro to Send Files by Email" using her array feature, but that array is fixed. I wish to change that fixed array into a variable array, much like the thread "Attachments to New email item" dated Oct 15, 2013. My ultimate goal is to run this as a macro or VBA once a month whereby the code would scan the invoice directory and for every unique invoice (there might be 15 or so), open a separate email using a pre-existing template (.oft) with the same 17 first letters and attach that invoice file and then display it. For example "P010213252 (FC42) YYYYYYYY.pdf" invoice file, then open the corresponding .oft template "P010213252 (FC42) XXXXX.oft". I'm using Outlook 16 under Win 10. I can get the fixed array to work to a certain extent, but the filename attached to each template is always the first .pdf file. I presume I need a second array for the .oft directory. Is there code available that can compare the two directories, one holding the invoices.pdf and the other holding the templates.oft, and if a match is found with the first 17 characters, then open that template .oft and load the matching .pdf file? I've searched but cannot find it. If it exists, please let me know. Thx.
https://forums.slipstick.com/forums/46-using-outlook/post-thread
Because both are files, I think you could get a file name in one folder, look for a match in the other - it would be slower than reading both and creating arrays to compare.
This should read the folder and create an array - (untested, so i might have a typo or mistake) - then use each entry to check the other folder..
Dim FileDir As String
Dim strFiles
FileDir = "K:\Files\"
TemplateDir = "K:\Templates\"
strFiles = Dir(FileDir, vbDirectory)
While strFiles <> ""
If strFiles <> "." And strFiles <> ".." And Right(strFiles, 4) = "docx" Then
strList = Left(strFiles, Len(strFiles) - 5) & "." & strlist
Dim myArray() As String
'Use Split function to return a zero based one dimensional array.
myArray = Split(strList, ",")
or if the template names all use the same format - create a string with the template folder names and if the value in in the arrary is in the string, use it to create the tempate name.
For i = LBound(myArray) To UBound(myArray)
If InStr(LCase(otherFolderList), myArray(i)) Then
templatepath = TemplateDir & myArray(i) & ".dotx"
' do whatever
Next i
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
Diane Poremsky Add Attachment Names to Message Before Sending New Slipstick.com Articles 0
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
K VBScript Outlook, add attachment Outlook VBA and Custom Forms 1
R Add image within email and not attachment Using Outlook 2
J Is there any restrictions to the number of Attachment i can add? Outlook VBA and Custom Forms 3
M Add-in for verfying recipients email address is in the attachment Outlook VBA and Custom Forms 1
A Attachment not display when add to mail Outlook VBA and Custom Forms 10
G How to add a folder shortcut to outlook quick access toolbar? Using Outlook 5
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
B Searching for a Add-In Using Outlook 3
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
J vb to c# for Outlook add-in. Using Outlook 0
twofivepie GTD Netcentrics add-in for 2016 Outlook VBA and Custom Forms 13
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
