Send Again NDR
JPza
I had an issue with a mail gateway that bounced 99k journal emails back into our NDRmailbox, about 55gb worth.
Is there any way I can automate resending of these emails ? I've searched online but haven't had much luck.
To be more specific, to resend one of these emails you would open the message, and the option "send again" would be available.
When you click on this another form would appear with the email / resend to / resend from. This would resend the message with its original timestamp/headers and the 3rd party Archive platform would ingest as normal.
Emerogork How do I activate the "Send Again" option in Sent Mail folder? Using Outlook 1
pwatts2 Restrict some lists to only BCC send option Outlook Wishlist 2
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
R Can't send messages to groups in Outlook Using Outlook 2
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
D Delay Send not working Using Outlook 3
F Send multiple batch tasks to single person Using Outlook 3
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
D Default Send Account that Works? Using Outlook 0
