The way expand/collapse folders is actually meant to work?
rseiler
Outlook.com (as MS Exchange)
There's an Advanced View setting in "Group By" called "Expand/collapse defaults." If it's on "As last viewed," what should that do, exactly, for the behavior of the expanded/collapsed state of sections like "Last Month" and "Older" in Inbox?
My naive interpretation of it is that it should honor how you have the expanded/collapsed state of various sections in Inbox (or other folders with the view) set. So, for example, if you have "Older" collapsed but the rest expanded, it should stay that way unless you change it.
It doesn't. Most of the time, when you click out of Inbox into other folders in the tree (Deleted Items, Sent Items, whatever), and then go back to Inbox, you'll find that anything previously collapsed is expanded. But sometimes it's not, and when you return to Inbox, you'll find things just as they were!
If there's any reason for this, I've yet to figure it out. At first, I thought it might be determined by what view the folder you're clicking over to has, but that doesn't seem to be the case. It just seems random and seems like an outright bug. This behavior is present in the latest Office 365 version, at least. I doubt this is anything new.
What do you think? Thanks.
It should keep the folders collapsed as they were the last time you used the folder.
But... Views are weird and can get messaged up, especially when you use the same view on different folders - it makes a "one-off? copy of the view in the folder but it can easily be replaced/reset by the default view. Try making a copy the view and applying that to the folder - does the collapse state work better?
rseiler
OK, I did that, calling it "Inbox" for clarity, setting it to "This folder" (instead of the usual All Mail), and applying the view. But it appeared to make no difference at all relative to this issue, since switching away from Inbox and then back finds any section previously collapsed to be expanded.
A expand/collapse group under view tab is grayed out in outlook 2007 Using Outlook 2
K Outlook 2010: Remembering expand/collapse views Using Outlook 2
K cannot expand the folder outlook 2007 pst Using Outlook 1
S Automatically expand a folder when new mail arrives Using Outlook 7
C Unable to expand ANY folders after adding another gmail account. 2007. Using Outlook 4
B OL 2010: Move to/copy to folder: how to expand list of options? Using Outlook 2
K How to expand the recipients field on an outgoing appointment? Using Outlook 1
S New-MailboxExportRequest - EXPAND 10 item import limit (PST IMPORTS) Exchange Server Administration 3
K Automatically expand Gmail mail account Using Outlook 1
N auto expand all folders and subfolders in the inbox Using Outlook 3
M Expand query builder permanently - outlook 2007 Using Outlook 3
S cannot expand folder. in use by other application__ Using Outlook 2
R How do I expand all distribution lists in the To: section? Using Outlook 4
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
J Expand Distribution List on Send Outlook VBA and Custom Forms 1
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Macro to Change sort and collapse groups in Mail folder Outlook VBA and Custom Forms 9
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
L Merge two contacts folders Using Outlook 1
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
GregS Many Sent Item folders Using Outlook 3
B Reorder folders in Outlook Outlook VBA and Custom Forms 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
oliv- FASTEST METHOD TO ENUMERATE FOLDERS Outlook VBA and Custom Forms 3
