Save attachments using hotkey without changing attributes
ofw62
Current method:
open mail
select attachment(s)
save to
select folder
[OK]
close mail
next one ..
the date attributes of the files saved that in that way are updated to the date of saving (create/modified/access date)
Would there be a way to have these files saved
a. without having to open the mails on by one
b. preserve the original attributes, at least the creation date.
No doubt there are 3rd party tools (like EzDetach, payware) but I wonder whether there would be a native solution
or using a free script?
Office 365
I have noticed:
1. Article : Save and Rename Outlook Email Attachments with 3 scripts and many comments
first requiring
2. A registry patch outlined in Run-a-Script Rules Missing in Outlook
Now, after changing the registry, which script should I use?
I would like to have the name and then the created date added.
So, for example, file name reads: file-xyz.xlsx
the save as : file-xyz ddmmyyyy.xlsx (or file-xyz dd-mm-yyyy.xlsx)
Is this possible?
I would use the middle one - the run a script rule version. The first is manual, the last increments identical file names.
Adjusting the saved file name to meet your needs is generally easy enough
DateFormat = Format(Date, "yyyy-mm-dd ")
file = saveFolder & DateFormat & objAtt.DisplayName
Gives "date filename.ext" format. to do filename-date.ext format, you need to get the extension stick the date in before it.
you can use something like this from the first macro - it's actually better to get the position of the last dot then get the extension, unless you are only looking for specific file extensions.
For Each objAtt In itm.Attachments
' get the last 5 characters for the file extension
strExt = Right(objAtt.DisplayName, 4)
' clean the subject
strSubject = itm.Subject
ReplaceCharsForFileName strSubject, "-"
' put the name and extension together
file = saveFolder & strSubject & strExt
From another macro on the site - this would only save the ones that match the extensions.
' This code looks at the last 4 characters in a filename
      sFileType = LCase$(right$(objAtt.FileName, 4))
      Select Case sFileType
' Add additional file types below
      Case ".xls", ".doc", "docx"
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Diane Poremsky Save Attachments to the Hard Drive Using Outlook 2
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
C Save outlook attachments and rename/append files with identifier from subject line Outlook VBA and Custom Forms 3
D Save pst and attachments as a PDF File Outlook VBA and Custom Forms 3
E Outlook prompts to save attachments when no changes have been made. Using Outlook 0
M Save Attachments Event? Using Outlook 0
R VB code to bulk save attachments deletes message Using Outlook 1
O closing outlook prompts to save all opened attachments Using Outlook 2
M Outlook 2007 - Save outgoing attachments to network drive on sending? Using Outlook 1
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
U Save messages and attachments for a date range Outlook VBA and Custom Forms 2
M save attachments code? Outlook VBA and Custom Forms 1
N Save Selected Email Message as .msg File Outlook VBA and Custom Forms 10
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
