Custom Form Controls Not Visible To Recipient
nhdan1501
Outlook.com (as MS Exchange)
Hi All,
Very new to this forum. I appreciate any help I can get.
I have a custom form message with controls (checkboxes, date controls, etc.) that users fill out. After they send the message though, I am not able to see the controls that conveyed vital information. I just get a normal outlook message format with none of the controls I put in the form.
I am putting together an Excel Form that can be inserted into the body of a message for the time being. But, for ease of use, I am wondering if I can make a custom message form with controls and have the recipient of the custom message form see the controls and information conveyed by them as well.
Dis you make a separate read layout? Are the users within your exchange server? The data is transferred using TNEF blob and needs to use the custom form - an number of things can remove the TNEF blob and it works better if you publish the form in the org library.
nhdan1501
Yes I did make a separate read layout. This to me means that the "Separate Read Layout" is checked in the Form>Page tab. Should I uncheck this if I want to view whatever was on the "compose" page?
I do not have an exchange server to publish the form to. Public Folders is the only other option.
No, you don't need to uncheck it. This is the problem:
If the senders don't have the form published in their outlook, it's not going to work right. It also needs to be in RTF format, which is not assured when sending to the internet. The organizational forms library solves this problem for coworkers but external users need to have the form installed to have any chance of it working.
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
S Custom form with dropdown Using Outlook 0
P Custom form reverts from task Outlook VBA and Custom Forms 1
L Outlook Custom Form Using Outlook 2
Diane Poremsky The custom form cannot be opened. Outlook will use an Outlook form instead. New Slipstick.com Articles 0
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
A Get shared calendar name or id in custom appointment form Using Outlook 0
A Updated custom form not showing with old items Outlook VBA and Custom Forms 2
C Custom Application Form send Email to Another User Using Outlook 1
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
X Help with custom form which is very similar to Tasks Outlook VBA and Custom Forms 6
T Create custom calendar entry form... Outlook VBA and Custom Forms 3
