iCloud folders in Outlook are not the same as on iCloud
jChambler
Outlook 2007
I'm using windows 10 with Outlook 16 and have an updated version of iCloud running. The list of folders on Outlook are old ones which have been deleted on iCloud. When I delete them on Outlook they reappear. I'm guessing that the folders are not syncing with iCloud in the profile on Outlook. I have signed out of iCloud and deleted the files on the PC and reinstalled iCloud but they are still there. Is there a stored file on windows that keeps this info and it reloads it when I reinstall iCloud? Any help would be most appreciated.
Jonathan
The folders and items are in an icloud data file. You'll see it in File, Account Settings, open the account settings dialog, Data files tab.
I recommend signing out of icloud so its removed from outlook, open outlook to verify the icloud data file was removed then close outlook and sign back into the icloud. It will resync everything down, to a new data file.
When you sign out, do not choose the option to create a backup copy of your calendar & contacts. It's not necessary, since you are going to sign back in.
jChambler
Outlook 2007
I believe I have followed the instructions as advised, I didn't save a copy but chose to delete the data on the PC. The account settings under the Data files tab After signing out of icloud, show the icloud file is gone but the mail .ost is still there and when I open outlook the folder structure is still there. I have then signed back into icloud and opened outlook and the same folder structure is still there, it hasn't updated them to the current icloud folders. The old ones are just empty.
Did it add an icloud folder set? After you sign into icloud app and set it up to sync with outlook, there should be an icloud data file on that page.
jChambler
Outlook 2007
It has added an iCloud file 469405CE-CBD8-4450-A11D-97BAE7001FBF.aplzod and a me.com outlook data file. On my folder panel, I see the iCloud folder and the me.com mail folder. When I expand the me.com folder the list of mail folder doesn't match the folders on iCloud and it shows the folder that I have deleted on iCloud. If I delete them on outlook they go then reappear. When I empty the trash of the deleted folders they reappear there. I can't understand where they come from when I reinstall icloud on outlook.
The calendar & Contacts are in the aplzod files - imap email is in the me.com ost.
What is the name of the folder? It may be a required folder.
Commodore Weirdness with iCloud IMAP folders in Outlook 2013 Using Outlook 4
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
V iCloud Calendar invitations not sending Using Outlook 3
Horsepower Need iCloud mail only Using Outlook 1
Diane Poremsky iCloud, Outlook 2016, and Windows 10 New Slipstick.com Articles 0
Diane Poremsky Issues Syncing Outlook and iCloud Contacts New Slipstick.com Articles 0
Diane Poremsky Outlook and iCloud Sync Issues New Slipstick.com Articles 0
M icloud removed my contacts Using Outlook 7
H Can't connect to icloud Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy New Slipstick.com Articles 1
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
J Issues in Canceling iCloud Configuration and Reverting to Local PST Configuration Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
B Repairing iCloud damage Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
D iCloud for Windows v.4x Using Outlook 4
S Using iCLoud Contacts for Outlook Email Using Outlook 1
D iCloud vs Exchange Using Outlook 3
J Auto Accept Notifications from a shared icloud calendar? Using Outlook 4
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
V iCloud not syncing categorized calendar events Using Outlook 7
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
K Outlook ICloud Data Folder Using Outlook 2
