Custom Calendar Print Suggestions?
mrsburgessa
Outlook 2016 64 bit
I'm desparately trying to get my school to move from a very manual process using a spreadsheet to using the room scheduling in Outlook.
The biggest obstacle is that they are insisting on still having a printout inn a format at least similar to this one. Does anyone know of a way to get something even close to this from Outlook?
Thank you!! :)
2714
A Get shared calendar name or id in custom appointment form Using Outlook 0
T Create custom calendar entry form... Outlook VBA and Custom Forms 3
R printing custom number of calendar days in weekly view format Using Outlook 1
S Can I link custom designed forms to a specific calendar? Using Outlook 5
S use the custom form to show meeting request in recipient's calendar Outlook VBA and Custom Forms 1
P Create appointment to custom (shared) outlook calendar Outlook VBA and Custom Forms 3
J Getting values of custom categories set on Calendar folder Outlook VBA and Custom Forms 2
H add an appointment for a custom calendar, vba excel Outlook VBA and Custom Forms 2
E Custom formula for columns Using Outlook 3
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
O Searching for Custom Flags Using Outlook 3
