OLADD.FAE Error When Exporting Contacts
joe361
Outlook 2013 32 bit
When I try to export contacts, either PST or CSV, Outlook 2013 32bit will restart and the following error is in event viewer. This is an Exchange account using Windows 10.
Faulting application name: OUTLOOK.EXE, version: 15.0.5153.1000, time stamp: 0x5cff9c10
Faulting module name: OLADD.FAE, version: 15.0.4454.1000, time stamp: 0x509a38ed
Any help will be appreciated.
BTW, you aren't using outlook installed on the server with the exchange account? If so, you need to run fixmapi.
lindagriffithh
Outlook 2016 64 bit
Maybe it is worth reinstalling for 64 bits? At the same time and change the computer for the better.
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
M Error 0x 800CCC92 Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message New Slipstick.com Articles 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
J Error 75 Outlook VBA and Custom Forms 4
B "The properties of the message…have been changed" error Outlook VBA and Custom Forms 1
I Windows 10 - .msg files on disk show Explorer popup error Using Outlook 5
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
