VBA to auto forward message with new subject and body text
melisa_d
Outlook on the web
I know this gets asked a lot but none of the solutions I have found seem to be working for me. I am trying to auto forward an email from a specific sender and with a specific subject to a list of new recipients. I'm also trying to change the subject and body of the email when forwarding. I have Outlook 365 and I am using the following VBA code which gives me no errors but it doesn't do anything... What am I doing wrong? Or is this code just outdated? Please help! TIA!
Public WithEvents objInbox As Outlook.Folder
Public WithEvents objInboxItems As Outlook.Items
Set objInbox = Outlook.Application.Session.GetDefaultFolder(olFolderInbox)
Set objInboxItems = objInbox.Items
Private Sub objInboxItems_ItemAdd(ByVal Item As Object)
Dim objForward As Outlook.MailItem
If TypeOf Item Is MailItem Then
Set objMail = Item
If (objMail.SenderEmailAddress = "sender@test.com") And (objMail.Subject = "Test") Then
Set objForward = objMail.Forward
With objForward
.Subject = "Custom Subject"
.HTMLBody = "<HTML><BODY>Type body here. </BODY></HTML>" & objForward.HTMLBody
.Recipients.Add ("recipient1@gmail.com")
.Recipients.Add ("recipient2@gmx.at")
.Recipients.ResolveAll
.Send
The code should work.
Did you set the macro security to low and restart outlook?
Change .Send to .Display during testing so you can see the message without actually sending it.
I often add msgbox "macro running" as the first line in macros that aren't working correctly to see if the msgbox comes up . If you use more than one msgbox, change 'macro running' to give a hint where you are in the code. Maybe add msgbox objInbox.name to the startup so you know it is running.
Although your code is fine, you can just use item as the object
'see if it is running
msgbox item.subject
If (item.SenderEmailAddress = "sender@test.com") And (item.Subject = "Test") Then
Set objForward = item.Forward
With objForward
.display
melisa_d
Outlook on the web
I copied this exact code and sent a message to myself - absolutely nothing happens. No message, no emails forwarded. I selected "enabel all macros" and "apply macro security settings to add-ins" in outlook macro settings. I'm at a loss, must be doing something wrong...
melisa_d
Outlook on the web
msgbox item.subject
With objForward
.display
Basically I copied this code into the VBA window "this outlook session" and saved. Then exited Outlook and re-opened. Nothing at all happens when I send myself an email from the address I specified...
melisa_d
Outlook on the web
Ok, so my original code suddenly worked somehow. I only have one more question. Is there a way to remove the "From", "Sent", "Subject" and "To" section that shows up on the bottom of the forwarded email?
Yes. use the original body in when you rebuild it. (use the object name you're using in your code).
.HTMLBody = "<HTML><BODY>Type body here. </BODY></HTML>" & item.HTMLBody
chrisasir2
I am very new to this outllook programming.
Kindly let me know how can i run this private subroutine ? when i go to run i am not seeing the macro?
This auto forward subroutine will automatically detect new mails on arrival ? Do we need to configure anything ?
Thanks and Regards.
Anand
That specific on watches a folder for new mail -_ItemAdd in the name tells me that. It might work in a rule, if not the 'title' needs edited slightly. To test the script without sending messages, use this - the macro name goes in before the end sub. This should work with the itemadd macro too.
Sub RunScript()
Set objApp = Application
YourMacroName objItem
This has more information on using a script in rules:
JordyH
Outlook 2016 64 bit
I've copied the code from the OP and changed to my liking and got it working, which I thank everyone here for :)
What would I have to change if I want this to monitor a shared-emailbox instead of my own inbox?
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
