Outlook 2010 is Auto Purging when not configured for that
bbrener
Outlook 2007
I have used Outlook 2010 for many years. whenever I delete an email from an IMAP folder it crosses through and I have to hit the purge button to actually delete which is what I want as it allows an undelete.
I have just updated Windows 10 to v1903 and now Outlook is automatically deleting purged emails as soon as the folder is switched. There is a setting for this and it is NOT set yet it still deletes on exit or folder switch.
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
B Timed events created in iPhone auto-change to All Day events in Outlook 2010 Using Outlook 2
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
G Using Outlook 2010 on POP3 to Outlook.com auto deletion on Web Using Outlook 3
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
