Outlook 2016 Does not Shutdown Correctly
bbrener
I have recently installed Outlook 2016 from Click to Run. When I close it, it does not close and leaves the Outlook.exe process running as viewed in Process explorer with a bunch of subtasks. There is an icon on the bottom right that says 'outlook is closing' and it never does.
I have done the following:
* Disabled all add ins
* Repaired the installation
* Scanned the PST and OST files with Scanpst.
* Procexp does not show any other apps running tied to Outlook.
Any other ideas as to how I can find the issue?
bbrener
I also deleted .SRS files and tried /safe mode. It doesnt shutdown in safe mode either.
Markdc
Outlook 2016 64 bit
some of the simple tips are :
Try disabling the add ins
Some applications might cause this issue, so you need to uninstall them. Some of the applications that interfere with outlook are:
  • Fax software (such as WinFax Pro)
  • Virus scanners (Norton, AVG, Panda and Kaspersky are some known to have caused problems)
  • Anti-spam filters (for instance; Cloudmark)
  • Synchronization software (ActiveSync, BlackBerry Desktop, iTunes)
  • Windows 7 Sidebar Gadgets displaying Outlook information
  • Skype (View-> Show Outlook Contacts)
Next, try installing the updates of windows and updates related to outlook 2016
Further try running the scanpst command to remove corruption issues and errors.
These methods can help Outlook to shutdown safely.
I would not expect SRS to help. It's usually a 3rd party utility at fault. Check your addins - disable any non-microsoft addins and see if it stops then review the programs you use that use outlook data.
There was a recent bug that caused this behavior. It was fixed and is enabled after a couple of restarts - so you should have that fix. The symptom for this bug was the other Office processes are listed in task manager even though you did not open the application.
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
