Outlook 2016 Font Problem
Marc2019
I installed an Office 2016 on my Laptop, it was Ok, but the problem is when I use my Outlook, every email message sent by my friends from there office 365 outlook online to mine are in "Segoe" font which I found difficult to read. Hope you can help me, I already tried editing the font setting on "Stationary & Fonts" option on my Outlook settings but still it did not work.
Thank You!
It is difficult to edit the fonts on incoming HTML format messages. Those are set in the message by the sender. You can convert it to plain text - then the messages will wuse the plain text format. But it's difficult to switch individual messages to plain text format, its easier to display all in plain text and change the messages you need rendered in HTML back to HTML.
Marc2019
Thank you Diane!, But I would just like to ask how could you: "display all in plain text and change the messages you need rendered in HTML back to HTML." Can you teach me?
Carl_of
Outlook 2016 64 bit
In my opinion, Outlook is the best mail client in the world and you can ignore the small issues such as those you described in this forum. I want to back up my words with a web resource detailing why Outlook is better than other email clients. https://www.data-fellas.guru/10-reasons-why-users-prefer-outlook-over-other-email-services/ . Also, this site describes the most popular mail clients in the world, and I recommend you to read them. I hope you can solve your problems with this great program
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
W Search Incomplete Outlook 2016 Using Outlook 5
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
J Checkboxes when selected will appear in a textbox in Outlook 2016 Outlook VBA and Custom Forms 1
N Outlook 2016 Address Book lookup Using Outlook 9
