Outlook 2016 Junk E-Mails
freeman1961
Is it possible to subsequently check certain Outlook folders on Junk emails?
freeman1961
it was necessary to copy a large number of emails from the Deleted Items folder to the Inbox folder. Now I want to manually check these copied emails for spam.
freeman1961
The junk folder runs on mail as it comes down from the server - you can't trigger it manually (like you can with rules).
freeman1961
Thanks for the clear answer. Is there an external add-in program (addin) that could solve the problem?
N All my inbox/junk e mails & contact list have vanished. How can I retrieve them ? Using Outlook 2
I Junk Mail and PersonMetadata Using Outlook 2
J Junk mail doesn't work Using Outlook 3
T New Account Shows No Junk Mail Folfer Using Outlook 0
T Probem with junk mail folder in new account in Outlook Using Outlook 0
C Why can junk mail be from one’s own email address? Using Outlook 7
M junk mail folder Using Outlook 2
Diane Poremsky Junk Mail Filtering in Outlook New Slipstick.com Articles 0
K Emails stuck in 'Junk' folder Using Outlook 0
David Rahrer Change default Junk E-Mail folder Using Outlook 6
S Outlook.com - Junk files Using Outlook.com accounts in Outlook 1
R Not junk email Using Outlook 3
lotsbg Loads of junk in second email needs fixing Using Outlook 1
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
G filtering email with missing TLD to Junk Outlook VBA and Custom Forms 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
R Outlook 2007 junk mail Using Outlook 4
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
C Outlook 2013 Junk Mail Filters Using Outlook 0
L My junk email folder has disappeared - Using Outlook 0
Commodore Junk Mail filtering and IMAP Using Outlook 3
D Junk Mail filter Using Outlook 1
V Macro to view Junk Email folder Using Outlook 4
J Junk email Exchange Server Administration 1
V Emails going to Junk folder Using Outlook 2
A Junk mail Using Outlook 4
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
U Problems with junk mail folder... Using Outlook 1
R Emails suddenly going to the Junk email folder Exchange Server Administration 3
C starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering' Using Outlook 3
G Red crossed circle disappeared from Junk Mail folder Using Outlook 3
O Emails still going to Junk Mail Using Outlook 8
D Junk Mail location Using Outlook 1
J Junk email filer stopped working in Outlook 2010 (32 bit) on a 64-bit Win 7 PC Using Outlook 12
E Can rules be applied to the Junk E-mail folder? Using Outlook 2
C Junk Folder not operating Using Outlook 4
D Disable Junk Email in the Registry? Using Outlook 8
R Junk email window automatically minimizes Using Outlook 1
D User behavior influencing Junk mail designation Using Outlook 1
B Outlook 2003 junk mail issue Using Outlook 1
P Efaxes go directly to Junk Folder often even though they are in my safe sender list. Using Outlook 4
